Oil cooler line broken bolt hole
So I attempted to reinstall the banjo bolt of the oil cooler line to the transmission and the metal essentially broke away from it. I've attached a picture. What would be best here? Some sort of time sert? TIA
https://ibb.co/MfYHJbn
Sorry to be the bearer of bad news.
So, you need to fix the hole for the banjo bolt on the side of the tranny?
Such as, the transmission fluid hole, that is capped by a red fitting on the following photo:
https://ibb.co/df6JRMV
Well, bad news and good news.
The bad news, forget about fixing that hole.
The banjo bolt needs adequate torque to seat properly. And, the banjo bolt must also be square to the hole. Otherwise, the force of the bolt on the flare will be lopsided and it will leak.
You can't MIG or TIG that piece back. A proper weld has the weld go all of the way through the metal, on both sides. If the crack wasn't fully welded, then the crack would grow over time. Plus, since it's aluminum, it has "high" expansion and contraction rates, that are not perfectly matched with the weld material. There's not enough "meat" on the external piece, to be able to handle a different expansion/contraction rate at the crack/weld point.
The "good news" is that "only the bell housing" has to be replaced.
Gary Ferraro
Needless to say, this is something that has to be done by a transmission shop.
Good Luck!
https://www.youtube.com/watch?v=FtI3IpMcuqg
22.6 Bellhousing Swap & Reassembly
Gary Ferraro
Good Luck!
