Electric Problem in C-240 2004
I have an electrical problem in my Mb c240, the problem occurred after disconnecting the SAM, only now if the SAM is disconnected or not, it does not matter, since the problem persists, when I insert the key, it turns on the cluster, but at the same time turn on the high beam light (but not the high beams), the brake light, the display reads +85 degrees, the dashboard lights do not turn on, I cannot turn on any headlights with the selector and the light that indicates P, R, N, D does not turn on. (Sunroof, interior pilot and passenger lights work, windows work, brake and reverse lights work)
I don't know what it could be, I hope you can help me, thank you
