Replace Line to fuel filter? C240
Old Jan 1, 2022 | 11:46 AM
P Fay's Avatar
2004 C240 4Matic Wagon (w203) V6-2.6L || 2006 E 320 CDI (w211) L6-3.2L Turbo
My 2004 C240 4-Matic Wagon could use a new fuel filter, and unsurprising, all the lines to the filter are falling apart.
I've attached a sample eBay photo below to illustrate the 4 lines. (I don't have any decent MB diagrams of them.) I have some questions first, as I don't want to touch these lines before having a plan, because they will fall apart.
Questions:
1) Are the blue lines replaceable without pulling the entire tank, which I hear is a nightmare in this model? Maybe slide them in on top of the tank without dropping the tank?
2) If not, can I just replace the decayed rubber ends at the fuel filter (circled in red) and clamp a new rubber line to the blue line?
3) The bend at the other end (circled in yellow) is totally corroded. Any advice on fixing it? I'm not sure if I should only fix the corroded spot, or should I replace the entire line, though I can't see it.
2004 C240 (w203) fuel tank & filter
Old Jan 1, 2022 | 05:27 PM
RedGray's Avatar
2005 C230K Sport Coupe
Check out:
https://www.eeuroparts.com/Cars/Merc...0/Fuel-System/
Good Luck!
Old Jan 2, 2022 | 10:22 AM
P Fay's Avatar
Thanks. I don't want to remove the fuel tank just to replace the entire blue fuel line, because it involves removing the axle, fender, etc.
Does anyone know if the blue line is metal or plastic? I'm going to need to replace the rubber end of the tube, but I'll need to cut off the ferrule connecting the rubber.
Old May 4, 2022 | 01:17 PM
zubrato's Avatar
2003 C240 4Matic
Currently stuck with exactly this problem, did you find a solution?
Old May 4, 2022 | 02:10 PM
P Fay's Avatar
Sorry, but no. Unfortunately, I received no useful advice. I postponed until better weather, and because I had to clean and replace injectors, reset fuel pump circuit, etc.
The problem is still waiting for me to fix... or barring that, when the rusted metal or decaying rubber lines break.
Old May 5, 2022 | 07:33 AM
slammer111's Avatar
2003 C230K Coupe Orion Blue
I'm not sure anybody else here has had this issue at all. If you find a solution, please post any knowledge you gained into this thread.
Assuming the pipes are rigid, it almost looks like both lines can be snaked in from the fuel filter end?
Old May 12, 2022 | 01:57 PM
112233's Avatar
w203cl
I had a leak from a tiny rust hole at your yellow circle. I bought a longer fuel hose and clamped it above the hole.
I would use the polyamid plastic fuel lines and fiddle it above the tank
https://mb-teilekatalog.info/view_Su...=47&subgrp=035
Old Dec 5, 2023 | 09:42 PM
BadHombre's Avatar
C240
Good day, has anyone found a solution? Any links for removing the fuel tank.
I have a 2003 C240.
