Kleemannized
Alloy is good for 8hp more at the rear wheels so it's worth waiting a little longer for. A complete pulley replacement is a little better in that you can return the car to stock in case anything goes wrong and need warranttee work. The ring leaves tell-tale indentations where the screws pressed against the pulley.
What is involved in removing the Crank Pulley? Is drilling required or is it simply unbolted and replaced like the Alt pulley?
Reason I ask is I was leaning toward the Ring vs. the Alloy Pulley because no Crank Pulley removal was neccessary. Just a simple Alt pulley replacement and attachment of the Ring around the existing Crank Pulley, add the new belt and drive away happy.
I believe the Alt needs a 22mm, does anyone know what the Crank bolt size is?
Well now I guess I need to wait for someone to make the Alloy Pulley available, Kleemann or the as yet unnamed (Unknown) Pulley maker.
