Bi-X: W203/CL203 OEM Bi-XENON Upgrade, Auto-Levelling & Programming thread
#227
Location: Houston,TX-moving to The Woodlands,TX SOON!!!
Toyota Tacoma & Lexus IS250
Harris, I think its pretty much plug and play - only one new connector must be added/replaced to work with COMAND, also need to add another GPS antenna under the dash.
I don't know about taking the old radio out tho...I think it may be hard.....I'll tell you for sure after my install!!!
#228
It's easy to retrofit a comand on w203 it's almost plug ang play your stock radio connector will fit on comand connector as well as the d2b connector(cd)all you have to do is buy the c1 and c2 connector ang w203 gps antenna.Very easy and fun.
#229
#230
I am contemplating the same retrofit, it would be fantastic if you could get step by step pictures and instructions on the install of the Command and GPS Antenna (and then post them for us). Especially from Steve!
#233
2010 C300 4matic
Originally posted by Lynn
I don't think the tool works with the oddly shaped radio in the C's.
Funny story. At last year's auto show here, the C230 that my dealer provided (I work there) had the knobs pulled off the climate control. We couldn't buy just the knobs, so we had to get a new unit. If it would have slid out we could have replaced it easily. Instead of pulling the dash apart, we just took the knobs off the brand new unit and put them on the one in the car. That was several hundred dollars poorly spent. So don't lose any knobs in your cars, you probably can't replace them.
#235
C32
yup that sound very possible,i would do it if it came down to it,why spend hundreds of dollars on a knob that broke,Bagwell tell Steve i said hello,and if u like u can fly me out also,and i'll buy dinner what do think of that?
#236
W203
#237
uhhh...its not free for the flight(s)...I get a deal but its nowhere near free !!
I'm only flying him in because I've talked to him so much, I think it'd be cool to meet and also for the expert installation of COMAND.
#238
Administrator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
Originally posted by Matt230K
.... that my dealer provided (I work there) ...
Thanx
#239
2010 C300 4matic
Originally posted by amdeutsch
Sorry for the interruption of this thread but I couldn't help noticing. Are you able to help all of us 03 owners out and get us the "dyno mode / secret handshake info"? You 02 folks have capabilities that we lack. Peet, me, etc, we all would appreciate it.
Thanx
Thanx
#242
2002 C230 Coupe Black/Charcoal C5 C7 Auto
#243
Steve will be in Houston Dec 6th from about 230p until 840p. After the one hour+ COMAND install (YES I'LL TAKE PICS..if it doesn't slow him down!!!!), we'll try to go to Pappasitos or Luthers for dinner -- something close to George Bush Intercontinental Airport.
#247
![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
#248
I just moved up here from Woodlands (where I lived for 10 years) and I miss Pappasitos sooo much. Theres no good mexican food here in Washington
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
#249
'xenon present' setting question
hi all, i know this subject has been inquired about a million times but i couldnt find an answer to this...i plan on getting the bixenon lights and want to change the 'xenon present' setting PRIOR to installing the bixenon lights...will my stock headlight bulbs (hi/low) still work with a 'xenon present' mode turned on? thanks a lot!
