View Poll Results: FrankW's Obsidian Obsession
FTW
![](https://mbworld.org/forums/images/polls/bar2-l.gif)
![](https://mbworld.org/forums/images/polls/bar2.gif)
![](https://mbworld.org/forums/images/polls/bar2-r.gif)
![](https://mbworld.org/forums/clear.gif)
69
100.00%
FTL
![](https://mbworld.org/forums/images/polls/bar3-l.gif)
![](https://mbworld.org/forums/images/polls/bar3.gif)
![](https://mbworld.org/forums/images/polls/bar3-r.gif)
0
0%
Voters: 69. You may not vote on this poll
Frank's C32 Obsidian Obsession
MBworld Guru
white and whiter
Originally posted by bajaiman
A set of lowered springs or Coilovers ... it'll be just perfect
... btw.. are those 18"?
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
don't know about the springs or coilovers tho...might be in the future...
MBworld Guru
white and whiter
blah...they are REPLICAs...not that much too...can't say how much. my bro's friend don't want to get the retail price for these replicas killed...if you know what I mean...
just say all four is = one real rim.
#38
MBworld Guru
white and whiter
don't know why the red x, I think it's because something's wrong with the e46fanatics server...
anywayz, if you have mbklasse.com account you can see them here http://www.mbklasse.com/forums/showt...4422#post64422
#44
MBworld Guru
white and whiter
Smoked the clear part of the taillight.
step 1: take out the plastic part that covers the trunk latch area. There are 8 small square clip and 4 mid size round clip and 2 large clip that holds the entire piece together. To remove the clips (8 small and 4 mid), you'll need a small flat-head screwdriver to prey all the clip off. They should come right off w/ a little extra force. They will not break if you are careful. The two large clip near the wheel well will come right off using the screw driver as well.
2. once the blk plastic cover is off, you should get easy access to the taillight. take off the bulb holder and disconnected the wire and put it aside.
3. locate the 4 bolts that secure the taillight housing. I forgot what size rench did i use, but you guys should find it easy.
4. once the taillight is off the car, now it's time to show your steady hand. You'll need some masking tapes (those paper ones), a blade ( I used my modeling blade), and some cans of tint spray and clear coat. when you are taping the lights don't forget to clean them first because you don't want the tape to gather dust and come off when you are spraying. The straight edge is easy, you can just lay down the tape, but for the round edge you'll need to use the blade to cut the edge (make sure you know exactly where the clear and red part seperates.
5. after the taping is all done, you'll need to cover up the rest of the red area w/ newspaper or anything will be fine too.
6. clean the clear part again to make sure there's no dust etc. Hold the spray can 3-4 feet above the taillight and spray over the part you want to smoke. Do it lightly and over again until you got the darkness you want. If you F-ed up, some rubbing alcahol should clean it up if you do it fast before the thing is dry.
7. once you get to the darkness you want wait till it dries a bit and then use the clear coat. Couple layer is probably needed.
8. let it dry and put everything back where it belongs.
note: depending on the brand of the tint spray you use you'll need to follow the instruction on the can. I used the paint called Model Painter 2949 transparant black paint.
#46
MBworld Guru
white and whiter
also updated the front corner too. the previous one I didn't smoke it enough, so a special person did it to his/her oem one and gave it to me.
a comparison before and after.
