View Poll Results: FrankW's Obsidian Obsession
FTW
![](https://mbworld.org/forums/images/polls/bar2-l.gif)
![](https://mbworld.org/forums/images/polls/bar2.gif)
![](https://mbworld.org/forums/images/polls/bar2-r.gif)
![](https://mbworld.org/forums/clear.gif)
69
100.00%
FTL
![](https://mbworld.org/forums/images/polls/bar3-l.gif)
![](https://mbworld.org/forums/images/polls/bar3.gif)
![](https://mbworld.org/forums/images/polls/bar3-r.gif)
0
0%
Voters: 69. You may not vote on this poll
Frank's C32 Obsidian Obsession
#1251
MBworld Guru
white and whiter
teaser...new rotor ring and ceramic pads. probably will look stupid with the rear being drilled and slotted, but whateverz...should perform better with less squeal
![](https://mbworld.org/forums/attachments/c32-amg-c55-amg-w203/154286d1239600203-opinions-please-moto_0080.jpg)
#1256
MBworld Guru
white and whiter
the good and the bad...
the good: had the rotors and pads installed. did a light break in.
the bad: found out the lower control arm bushings are badly shot on driverside. pretty much done for on the passenger side as well. my intuition was right which I feared. LOL #%#@$%#$@^
#1258
03 c320
#1259
MBworld Guru
white and whiter
you can physically look at it. it should not have any cracks or great openings.
edit: i guess that's per side, not per arm. LOL
#1261
03 g35 coupe...........02 c32 Sold
http://cgi.ebay.com/ebaymotors/MERCE...Q5fAccessories
#1262
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
Frank - why are you looking at replacing the complete arms & not just the bushes. Are your ball joints shot?
#1263
I remember the mechanic quoted me $260 to replace and install my rear control arm brushings for my integra, when i could just buy new control arms with new brushings in them for $100.
#1264
Super Moderator
Yeah maybe Mike - In South Africa it is considerably cheaper to just pop a new set of bushes in at the dealer. Takes them about 1.5 hours. The bushes have been substantially reduced in price this end.
#1265
For 1.5 hours labor I would have let them do mine. The standard labor time here is to look in the book for the allotted time, then multiply it by 3 or 4.
#1267
Super Moderator
OK - I get you guys - sounds like stealership is an accurate description. It really is an easy job with the right tools & a hoist. What the hell do these guys do with all the time.
#1269
MBworld Guru
white and whiter
the ball joints are fine, but this will probably become a DIY job with help from a few friends, so replacing the arms completely is a lot easier i guess. haha
#1271
MBworld Guru
white and whiter
have you checked these out? There $260 shipped for the left and right set.
#1272
Super Moderator
Can you please find out if MBUSA reflect a new part number for the redesigned bushes. In South Africa they say the bushes have been redesigned but under the old part number??? I find this strange unless its a 2 digit suffix change.
#1273
Frank - there is indeed a new design on the bushing - They have been made softer - see pdf attached.
#1274
Super Moderator
Yes Mike, any increase in compliance in a vehicle will generally have an adverse effect on handling - The reason most American cars are bad handlers in the absolute sense. Benz did this for longevity, improved comfort & endless complaints about tyre noise transmission into the cabin - or at least this is what I've managed to ascertain - this is not their marketing hype - maybe the comfort part is. They have been very careful as to which bushings changed & made the steering more direct at the same time. People don't seem to have noticed any adverse effects on handling. You would probably need to do a side by side test to pick it up.
#1275
MBworld Guru
white and whiter
![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
