View Poll Results: FrankW's Obsidian Obsession
FTW
69
100.00%
FTL
0
0%
Voters: 69. You may not vote on this poll
Frank's C32 Obsidian Obsession
#1333
MBworld Guru
white and whiter
update on misfire.
recap on previous diagnosis: after changing out the cylinder #4 plugs and reset the misfire code on #4 the code never came back. However misfire had continued. There was the pending code on #6. I changed swap the coil pack on #4 with the CLK320's coil pack and found out it wasn't the issue with the coil pack. which is good news for #4. for #6 I did not check the coil pack however. the pending code continues.
today: installed the magnecor wire at my local shop. also tested the old wires for resistance. crap load of them are ...well...crap. magnecor wires installed and instantly felt lots of power came back. BUT...yes...there's a BUT....idle is still a little rough (way better than before, but still). so I am going to check the plugs on #6 and then the coil on #6 as well today.
#1335
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
#1336
MBworld Guru
white and whiter
btw, dropped the W204 for service today for front suspension popping noise when backing up. should be a TSB item.
got a loaner PT Cruiser today. It's sooooo retro that it doesn't have power mirrors and how the hell do American engineers figure that you only need "one touch auto" for lowering the window and not up?? and four window switch right in the middle of the center console in front of you.
#1337
I drive a Toyota Hybrid...
#1339
MBworld Guru
white and whiter
ok, so I pulled the plugs out of the #6, cleaned and checked. plugs look great and doesn't seem to be damaged. put everything back and made sure 100% everything is tight and in order.
started the car and bad idle continues. it feels worse in Drive than in Park, so this is still a misfire somewhere.
I'm not convinced that the coil pack is bad yet. going to run to the store and pick up 4 more NGK iridium IX plugs and replace 5 and 6 tomorrow. since the 4-5-6 side was the side that showed pending misfire codes.
now, the question: when the coil goes bad because of our twin plug design. do they go bad for both a and b on a single coil? OR there's a chance only a or b on a single coil goes bad?
I gotta get the pending code read again tho...changing the wires and I lost track of which coil pack is which...
#1340
Super Moderator
#1341
MBworld Guru
white and whiter
btw, can the STAR diagnostic pin point which coil pack is bad?
so I swap the #6 coilpack with the 320's. same rough idle. now I have no f-ing clue what is going on. taking it to a mechanic friend who has a odbii reader that can see if there's any pending code and go from there. If the STAR is the only way to figure out which coil pack is dead quickly without me swapping every coil then I'm gonna visit another local guy who has the STAR on hand.
never throwing in the white towel, but this one is not going down without a fight.
lastly...RANTING: F! ALL COIL PACKS!!!!!!
#1344
How about the signal to the coil? There are three wires going to each coil pack so I'm assuming one is ground and the other two are hot for respective coils. If you don't have an oscilloscope or frequency counter you can improvise with an analog DVM. Use AC reading and work your way down the voltage range until it shows on the needle. Check it against another coil pack. You can also check the power delivery to the plugs with an old fashion/cheap timing light and see how consistent the light is. Many newer digital volt meters have frequency reading capabilities.
#1345
If you really get desparate for answers, you can drive out to my guy by my pad to have them check it out. Just hit me up on my cell and I'll give you the contact info.
#1347
Super Moderator
The problem is that compression suppresses spark - a plug will fire properly in free air but under compression can fail to fire properly through bad plug or coil or excessive wire resistance or breakdown. This on a blown engine should show up at maximum volumetric efficiency - i.e. when the supercharger is at maximum blow pressure.
You say it's bad from idle - does it get worse when you load the engine & get the revs up on the SC? Can you feel the misfire pop with hand over the exhaust? I know on a twinspark 6 this can be difficult to detect.
I don't want to add other variables to the equation & I must say the problem sounds electrical after earlier scares. When last did that engine have a CPS? The day is going to come where we must take a plug out of each cylinder & do a compression test to check for a leaking valve. If for no other reason than to eliminate the possibility. Are all the vacuum lines in good order? They can't be too bad or you would get a fuel trim warning.
Can you please backtrack - What did you do to the engine prior to this trouble starting? Did you do or change anything prior to the trouble? You were talking about O2 sensors at one time - did you change them? A bad O2 sensor can cause stumble - that's however not what you are explaining.
Have you looked at the engine compartment in the dark at night with the airbox/es off. Can you see any sparks jumping around through the wire or coil insulation anywhere?
Good luck
#1348
I had a PT Cruiser convertible going from Vegas to the Grand Canyon, and have to admit that it was fairly fun.
Sorry to threadjack! Good luck with the fix, Frank.
#1349
C320 coupe
