I want to add heated seats to my car... '02 C240 Sedan
Old Oct 4, 2004 | 10:51 PM
miroj's Avatar
Originally Posted by Saprissa
Doug,
this is an interesting development... now I'm wondering if I've got these seats too... doubt it also, but maybe worth a look & see !
Let me know what you find. I guess figuring it out on mine would be easy since my seats are manual. So any loose wires under there might mean: heated seats, no ?
Miroj,
i think I would want the switch-row with EVERY single Possible option on there (Euro & US spec): IMS, Parktronic, Heated, vented, alarm, sunshade,
head rests, anti-tow, everything.... which part # is that one from all those you listed ?
Carlos
Saprissa@aol.com
Your manual seats are still wired for a range of functions. You may need to dig around for the wires.
The part number is the last one in the list. ALL OPTIONS + IMS + VENTED
A209 820 48 10 = all of the options + IMS + seat venting
a) You will need E-cla$$ seats or CLK seats to get the venting option. Ask Steve
b) Check the parts under CLK before ordering (your parts dealer will know)
c) [805] means it is for 2005+ cars (your parts dealer will know)
d) Be sure you plan to go ahead with it before you lay down the cash. There is a reasonable investment in cables and fittings. One small change like vented seats needs several parts.
Old Oct 4, 2004 | 11:00 PM
Saprissa's Avatar
From: San Diego, CA & San Jose, Costa Rica & Stuttgart, Germany
1959 220S / 1979 230 G / 2002 A210 AMG / 2003 C320 SC / 2004.5 C320 SS / 2005 ML350 SE / 2008 smart
thanks !
I'll probably never get the vented seats and some of those other options, but since I'm getting PTS and stuff, the full switch row would look cool.
I take it the CLK switch row fits in the C-Class W203 switch row cavity just the same ?
My car is a 2003, so no worries with all the new 2005 parts.
Carlos
Saprissa@aol.com
Old Oct 4, 2004 | 11:04 PM
Saprissa's Avatar
and, oh yeah,
what's the EURO cost for that A209 820 48 10 ?
if it does fit the W203.
Carlos
Saprissa@aol.com
Old Oct 5, 2004 | 04:36 AM
miroj's Avatar
thanks !
Carlos
Saprissa@aol.com
NEVER put 2005 parts in a pre-2005 unless it is something trivial like a steering wheel (errr .... is that trivial ?)
CLK and C parts are more or less the same thing except for the plastic and trim bits.
Old Oct 5, 2004 | 04:37 AM
miroj's Avatar
and, oh yeah,
Carlos
Saprissa@aol.com
I think your parts dealer is the best person to ask since that is the final supplier.
Old Oct 5, 2004 | 12:12 PM
wizkid's Avatar
Ford Pinto
I called the dealer just now. They are going to run down the correct seat covers for me for both sides and call me back with part numbers and prices. When I called, I was lucky to hear that the parts gentlemen that I usually deal with was in. He remembered me and knows I do weird stuff so he is helping me out.
I will have an update as soon as I have something to update.
Eric
Old Oct 5, 2004 | 04:56 PM
  #32
rgleason's Avatar
C240 2002
Aftermarket install
There are companies that do aftermarket installs of leather seat covers and seat heaters. I did an extensive search to find companies that install Mercedes leather because my 2002 C240 only has the leather inserts. However, I found no companies that do Mercedes aftermarket leather, except for some of the old models.
However, I think that an aftermarket leather installer could probably remove the present covers, install the heaters, and then reinstall the covers. When I have seen this done, the switches sit on the side of the seat on the right hand side for the driver and the left hand side for the passenger. See this website: katzkin.com.
**** Gleason
Originally Posted by wizkid
I Have a 2002 C240 Sedan.
I have power recline, raise, and lower. I have to manually move the seat foward and backward.
What would I have to do to add factory heated seats?
Order new seats like mine but with the heater option? I would also have to order the dash switches I guess.
Ease of installation? I'm up for a challenge here.
Any help would be useful as I can't find any one that has upgraded to heated seats with factory 240 seats.
Thanks,
Eric Barger
www.installuniversity.com - MB How To installation articles
Old Oct 5, 2004 | 05:39 PM
  #33
rockintunes23's Avatar
From: Delaware, United States. (First ~little~ state)
Mercedes-Benz
I sweat way tooo much in my car. I have a leather sofa and leather in the car. I'm only cooooool and right when I sit at the computer or in bed. HAHA. I wish I could get the cooling down seats where they have some kind of cooling thing like the big S classes. But I'm cheap, so here I am at the computer. haha
Old Oct 5, 2004 | 05:42 PM
  #34
CitronC230K_03's Avatar
2003 Citron Green C230KMT
vented seats are doable if you wanna spend the money. sunman is putting them in his C320. he has the driver side finished. im getting mine next spring.
Old Oct 5, 2004 | 07:55 PM
  #35
miroj's Avatar
**** Gleason
There is a company in Australia that does leather for Mercedes but to be honest the quality is tragic. If someone is going to spend money on leather then I wouldnt get the same thing over again, I would spend a little extra and get the AMG or Designo covers. Otherwise what is the point in spending extra ? It would be nice to keep the car original IMHO.
Using an installer is a good idea but putting in strange switches is a REALLY bad idea. The Mercedes switches and main cable harness are all you need to make the heat pads work - the timer is built into the CANBUS system.
Old Oct 6, 2004 | 03:44 AM
  #36
danielkwak's Avatar
MB
If you want to add heated seat in your car, I would recommend to contact Steve.
He added heated seats in my C320 changing the whole front leather, however it
wasn't that expensive.
Old Oct 6, 2004 | 04:12 AM
  #37
miroj's Avatar
At some point in time you will realise that Steve uses the exact same parts !
Old Oct 6, 2004 | 10:45 AM
  #38
jago1244's Avatar
2016 G63 ; 981 boxster GTS
Question how 'bout REAR heated seats??
any one try or think of trying it? with the aftermarket or a-class pads, cant someone run wiring and a separate discreet switch?
also, i have heard of 'rostra' (sp?) as a vendor of seat heater pads on other forums.
j.
heres the link to rostra: or is it 'roast ya'' ?
http://www.rostra.com/
Old Oct 6, 2004 | 05:51 PM
  #39
wizkid's Avatar
Ford Pinto
I will be fitting my rear seats for heat after this project is done. I may be using the A then.
Still haven't heard from my dealer yet...I guess I will just go by there next week.
Eric
Old Oct 6, 2004 | 05:59 PM
  #40
miroj's Avatar
Eric
If you are fitting rear heaters to the C-class then you might want to email Sunman because he already has it. I will looking in the parts list for E-class and S-Class and both have parts that can be used in rear heating for the C-class.
Old Oct 6, 2004 | 06:01 PM
  #41
miroj's Avatar
j.
I dont understand why anyone would need switches from a 3rd party. Its not as though $150 USD for the switches, wiring, fuse and connections are going to break anyones bank. You do after all have a frame under your seat that the connectors already click into.
Old Oct 6, 2004 | 06:03 PM
  #42
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Could it be because it is the way of modding a car.
Old Oct 6, 2004 | 06:09 PM
  #43
miroj's Avatar
Aaah, now why didnt I think of that. Its better because it ISN'T Mercedes. I can't say I have heard that concept before.
Old Oct 6, 2004 | 07:30 PM
  #44
SUNILP's Avatar
2015 E250D
For the rear, you will need a homemade harness with MB connectors and pins, a w202 seat heater control module, w210 seat heater switches, w210 bracket for switches, G class or A class heat pads. And a good file set to make those holes for the switches like I have in the rear.
Old Oct 6, 2004 | 08:28 PM
  #45
miroj's Avatar
I think the W210 rear seat heater is the same one used in W210 just with a W202 part number. Im pretty sure that W210 EPC refers to all the parts needed as does W220.
I was however under the impression that there was W203 switch plate with holes but it seems I was mistaken.
Old Oct 7, 2004 | 08:56 AM
  #46
jago1244's Avatar
i was refering to rear seats. i just assume that there are no existing connectors or switch locations available, and that one would have to determine where to tap into power and where to place a switch so rear passengers can control the heat. i wasnt considering whether on not to use MB parts. i'm no DIY guy, but i thought what i said made sense.
j.
Old Oct 7, 2004 | 05:13 PM
  #47
miroj's Avatar
j.
Let me assure you that Mercedes sells everything you can imagine. Rear mini-bar, rear seat laptop shelf, mobile internet gateway, PDA holder, illuminated door release and so on. Often people go to non-OEM product providers when all they need to do is look into the features and history of other Mercedes cars for the parts, switches and cables they need.
What are the odds someone in Mercedes hasn't thought of it ?
Old Oct 7, 2004 | 07:50 PM
  #48
trench's Avatar
2002 C230 K
Chances are that if your car was in a batch of high spec production models then the seat is most likely heated. It's random from what I hear.
Just a thought, perhaps if you have the original production form (not sure if that what it is called but I got a form with my car that had a long string of three digit numbers detailing all of the options and accessories used in the build) there might be a way to determine what pads were used.
Old Oct 7, 2004 | 07:56 PM
  #49
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
You're talking VMI. It doesn't go into the detail necessary: option code does not equate to PN used. HTH
Old Oct 7, 2004 | 08:03 PM
  #50
miroj's Avatar
We are talking about a free upgrade through the use of heated seat covers in cars with no heated seat option. This does happen however out of the 4 covers in the front there might be one to four covers installed with heating without having paid for it.
