05 C230 Kpmpressor Problem
Yes I think it does have power seats however they are not adjusted very much as I am the only person who drives it.
I only drive it when its not raining & largely in the summer. It does not do short jouneys to the store, when it does get driven its just for fun. I would guess it does under 6k miles in a year
However, you might also be dealing with a parasitic drain. The power seat modules are notorious for this.
Check the current draw when the car is sleeping (5-30 minutes after turning off the engine). The car will always be drawing some, but it should be somewhere around 0.05A after all the modules are sleeping. If the number is too high, unplug the seat modules (1 at a time) and see if the number drops.
Common warranties nowadays are 1 - 3 years. You stated the warranty is long gone - that means your battery is beyond its design life - manufactured obsolescence to help extract more $ from you.
You have deeply discharged your battery. Once you do that level of deep discharge, the life of the battery is reduced and many lower end chargers can't even recharge a deeply discharged battery.
Replace the battery, and as already stated above, check for a parasitic draw. Either fix the draw or keep a trickle charger on it to counter-act the parasitic draw and live with it.
A quick check is to start the car, and disconnect one of the battery leads; the alternator should be able to supply enough power to keep the engine running.. !?
