How to start the engine with one turn only
Old Nov 14, 2022 | 01:21 PM
lokaramen's Avatar
c200 kompressor w203
Hi everyone, I am very new with my c200 kompressor w203. My friend his has c180 kompressor and he said the car will start if i turn the key to 3rd position and release my hand (one turn only). But my car can not do like that. I have to hold at 3rd position for a while (2 second) or the car will not start. I am thinking about check a relay (or replace it). Does anyone have this problem and solution for this. Many thanks.
Old Nov 14, 2022 | 05:47 PM
slammer111's Avatar
2003 C230K Coupe Orion Blue
Is your friend's car an automatic and yours a manual?
Old Nov 14, 2022 | 08:02 PM
lokaramen's Avatar
mine is automatic too
Old Nov 15, 2022 | 01:43 AM
lokaramen's Avatar
if anyone know this problems please help me . I think this cause by starter replaced not right part or problem with the ECU (I already change ECU becasue my orginal is dead and the garage was get another one for me with copy program from old ECU to this new)
Old Nov 18, 2022 | 05:45 PM
slammer111's Avatar
Just noticed your mentioned your car is a W203 but your signature says your car is a W202. Which is it? We need to know the year of your car.
The W203 starter is identical between manuals and automatics.
There is probably some setting that wasn't moved over. You will need a StarDAS or Xentry to look into it.
Old Nov 18, 2022 | 07:53 PM
lokaramen's Avatar
just typing in mistake that my car is w203 and i am worrying that the previous owner maybe he replaced the starter of manual
Old Nov 19, 2022 | 04:52 PM
slammer111's Avatar
As mentioned, the starters are identical between manuals and automatics. Check your car configuration settings with StarDAS or Xentry.
