2006 Mercedes C230 Sport : sudden CEL resulting in rough idle Diagnostic Misfire
Old Dec 26, 2022 | 09:54 AM
M272RIV951's Avatar
Vehicle had been running great minutes before loosing power while in motion, CEL appeared on dash and idle was rough. Plugged diagnostic and cylinder 2 and 5 misfire. With engine running pulled coil electrical plug off and no change to engine idle at both cylinders. Replaced spark plugs,coils, fuel injectors , Mass airflow,Throttle body. Pulled intake manifold inspected vacuum hose swirls,flaps, pump diaphragms. I tested the coil plug for power as well as both injectors.
Old Dec 26, 2022 | 11:46 AM
190Efan's Avatar
1991 190E 2.3
Welcome. I would suggest that you post your question in the W203 section of the forum. That's where owners of the same MB you own will be able to help you. You can find the W203 section by scrolling down the forum home page until you get to W203.
Old Dec 26, 2022 | 06:06 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W203 forum...
