2002 M-111 engine vs. 2005 engine?
Edit: M111 stock boost is 7 psi and M271's stock boost is 11 psi BTW.
I'll keep you all posted.
-Danny
Mechanical engineers will tell you NOT to do it ! They have Mercedes running for over 10+ years.
Salesmen and racers will tell you to go for it ! They sell their Mercedes after 2-3 years.
It's your choice. If I were to do it, I would go for the proven KLEEMANN, CARLSSON or BRABUS set ups that involve more than just pulleys. Because the pulleys alone don't make the car ! But now we're talking $1000's not $100's.
Carlos
Saprissa@aol.com
I have driven coupes and sedans with both engines and auto trans. The torque picks up sooner with the M-111, regardless of the transmission. It's not exactly a "kick you in the seat of the pants" difference, but it's something I just....feel. I've had heavily mod'ed cars, and I know the difference. The 1.8 M271 is a good, solid aluminum block, but it needs the extra boost to match performance. I'd be wary of tweaking this engine too much because from an engineering standpoint, it's close to it's max limitations when it rolls out of the showroom (my humble opinion).
I do not have a pulley, and have not done any major mods for performance (maybe after the warranty runs out if I don't trade it in). My main point is that the older, iron block engine offers more torque at less boost, and therefor is probably more reliable. After all, Mercedes has used the same 2.3 liter iron block design as the M-111 (albeit with different heads, obviously) since 1953.
Well I guess we have to hope that the M271 block and heads are built to the same stringent engine specs as the M111 was. Also hey if VW's 1.8 can handle the boost enough to push past 275Hp then I would hope the M271 could handle a few more psi, to push it to 220-225Hp...
Yeah I think the M102 engine in my 190E is the same block as the M111!
SergC yeah the Renntech is good as well. Hopefully someone will do before and after dyno's and purchase one of the available kits so we can see what these tuners are getting!
I've put 59k miles on my GTI since new and the past 28k miles have been with 285 hp and 299.5 ft/lbs at the wheels. At 57k miles I had Aristocrat VW do a leak down and compresion test. Both tests showed the motor to have no wear. Seriously, the leakdown showed all four cylinders to be "at or less than" 3% and the compression was near exactly the same as a new motor.
If I do go with some type of pulley kit for my M271, then I will only go with a tuner offering revised fuel, air and timing to compliment the pulley. I think it's best to spend the money on a complete package that has been well tested.
I would think that MB would build a strong bottom end, even if it's made out of alumium, but only time and beta testers will tell.......
Scott
Also I'm thinking about Renntech wheels 8.5/9.2x18 on235/255 Pilots...
I'l post the results
