W203 rear stabiliser end link
Old Jun 17, 2023 | 01:47 AM
selwyng's Avatar
2001 w203 C180
Hi all,
I'm really confused. I have the dreaded squeek from rear suspension when driving over slightest imperfections on the road. I purchased the rear stabiliser end links from a parts store. When I took it to a mechanic he tells me that there is no place to fit the part, I.e. there isn't a place on the rear suspension that this part will fit in.
I drive a 2002, w203 c180 non kompressor. Below is the part that I purchased.
Old Jun 17, 2023 | 04:55 AM
ChrisHimself's Avatar
SPONSOR
11 E550, 16 AMG GTS, 13 S550
W203's should all have the same sway bar end links unless i'm wrong. I had no idea a C180 existed but I doubt it has bespoke parts since these are the ones for all of the C and CLK cars even the AMG's
If there is not a place to install them, you are either completely missing a rear sway bar assembly, or someone needs to stop working on cars which I would not think is the case.
__________________
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
Old Jun 17, 2023 | 05:38 AM
selwyng's Avatar
2001 w203 C180
Thanks! I'm going to take it to another mechanic later next week to confirm
Old Jun 17, 2023 | 11:28 PM
slammer111's Avatar
2003 C230K Coupe Orion Blue
Not sure if that is the exact part you need (I assume it is if FCP says so) but yes, those connect the rear sway bar to the strut assembly. Just take off a rear wheel and it's right there.
Old Jun 18, 2023 | 11:38 PM
selwyng's Avatar
2001 w203 C180
Thanks slammer111. Will definitely take it to another mechanic this week. Im hoping this solves the noise issue.
Old Jun 19, 2023 | 04:54 AM
selwyng's Avatar
2001 w203 C180
Took the car to another mechanic and he confirmed, my car being a 2002 w203, c180 non-kompressor doesn't have a rear stabiliser bar
