W203 Yaw Rate Sensor
So apparently my Yaw Rate Sensor broke down and I need to replace it, the serial number on it is A 002 542 72 18 Q01 which is mostly used for SLK and ML so it was kinda weird it had mine inside,
Now a car parts seller claims that I can use any other serial number for my car W203 - C220 CDI 2001 105KW so can please someone let me know if there's something to serial numbers for it?
Thanks!
https://www.ebay.com/p/1539382196
Got a picknpull near you?
I was thinking if I could fit a different serial number which is for C class and is way more cheaper.
Chances are you can fix it 4-free under 10mn....
How easy is it to open it up. Any pics?
Perhaps I may be able to help, for free also ✌️
I am guessing this issue deals with poor PCB connections - - I thought this sensor would be honestly reliable, not any more then
