Funny Smell from A/C Vents
Old Nov 3, 2004 | 05:02 PM
nlpamg's Avatar
Super Moderator Alumni
2019 GT3 RS, 2017 M3 30 Jahre
I've noticed that there's a funny smell/odor coming from my a/c vents. It comes on when I increase the temperature on the climate control and it has to heat. However, when it's cool, and the temp is low, there is no smell.
Has anyone had this problem? Is this a "known" problem? Thanks!
Old Nov 3, 2004 | 05:15 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
what kind of smell is funny smell?
like vinegar type smell??
Old Nov 3, 2004 | 05:17 PM
nlpamg's Avatar
Hmm... I can't really describe it, but I wouldn't say that it's that pungent as vinegar, but it does have this sour/stale smell...
Old Nov 3, 2004 | 05:35 PM
tyro's Avatar
BANNED
Probably antifreeze leaking
Old Nov 3, 2004 | 05:36 PM
nlpamg's Avatar
are you serious? ****! would I be able to notice that leak? I know it has the underbelly plate/pan, so how would I be able to check? Thanks!
Old Nov 3, 2004 | 06:27 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Search this forum for "mold". I remember it having been discussed.
Old Nov 3, 2004 | 06:28 PM
nlpamg's Avatar
mold? but the car is literally 3 months old? I'll check it out. thanks!
Old Nov 3, 2004 | 07:05 PM
f00b4r's Avatar
2001 C240
When I first had my car and it sat in the hot sun all day I would smell an amonia type smell from the vents... It went away after a while without me doing a thing.
Old Nov 3, 2004 | 09:41 PM
BabyBenz6spd's Avatar
2005 C230 Sedan 6spd
I "rarely" had this problem........but sometimes when I just have the heater on (A/C is OFF) , I get a skunk smell......but it would go away after couple minutes.....its not something so serious I would go to the dealer for though.
Don't know......lets hear more comments.
Old Nov 3, 2004 | 09:54 PM
toki999's Avatar
C230 Kompressor Sports Sedan
take it to the dealer, when i had 2002 c230k coupe, it was fixed, but not completely... and she mentioned it was the "mold" problem many mercedes benz cars have...especially in 2002's. it's odd 2005's do it. my 04.5 230SS have weird smell too. i'd better take care of it too
Old Nov 4, 2004 | 12:52 AM
I KOMPRZ's Avatar
2004 C230k (SOLD), 2005 C230k (Lease ended), 2004 Carrera 4 Cab, 2007 530i
Ok I had the exact same problem, took it to the dealer and it was a known problem to them. Apparently I wasnt the only one with the same problem. 3 or 4 months ago they had no solutions to it whatsoever, they sprayed some disinfectant into the vents but the smell came right back the next morning. I suffered the whole summer. I wrote to MB and complained several times, now my car is at the dealer they are swapping out the respirator. I hope that will take care of the smell.
Old Nov 5, 2004 | 12:56 PM
jsr's Avatar
jsr
I was told once that if you turn off the AC (like by hitting the EC button) a minute or so before you shut off the engine then it circulates enough air to get all of the moisture out of the system and doesn't cause that smell. I can't remember if it worked or not, but it is something to try if it bothers you that much. I was always too lazy...
Old Nov 6, 2004 | 02:42 AM
shorthair's Avatar
2014 C300, sport, black/black
In this car you will have to wait about 10 minutes for the A/C compressor to cycle down. You can turn it off immediately by pushing the EC button then turning the fan to off, then back on again.
Putting deodorizer (Ozium) in the A/C only makes it smell like musty Ozium. The dealer will have to use DWD2 cleaner to flush the evaporator housing.
Old Nov 12, 2004 | 01:23 AM
mtokfmak's Avatar
2002 C180 Wagon
Re: Funny Smell from A/C Vents
I have (maybe still) suffered from a funny smell for a year +. While running on a highway in October of last year, the cabin was suddenly filled with a vynil burning smell. I took the car to the dealer next day. They found an oil leakage (a very small amount) and fixed it. Nonethless, the smell did not go away (though less compared to the initial occurrence).
Last month, the dealer replaced the dust filter and cleaned the vents; however, this did not help either. They therefore replaced the blower motor (to elimiate a case where the brush is worn) and the batter (to a sealed type to elimiate a case of hydrogen rising from my old battery) last week. Although I have only driven for about 30 - 45 minutes this week, the smell seems to be a lot less. I will be driving more this weekend and hope that the smell is gone now for good.
