W203 180 Kompressor M271 compression numbers?
Hi guys, I'm reading these two threads:
https://mbworld.org/forums/c-class-w...n-numbers.html
https://mbworld.org/forums/c-class-w...o-start-2.html
But for me is not clear what's the compression numbers (in bars) for each cylinder. And what's the permissible difference between them.
I know I'm a bit dumb, so that's why I'm asking for help.
Thanks in advance.
Thanks in advance.
https://www.popularmechanics.com/car...test-14912158/
https://www.motortrend.com/how-to/en...pression-test/
FAirly consistent readings across all cylinders means your engine is relatively healthy. I hope that helps.
