2005 C230 kompressor- can I change steering reservoir without removing pump
Old Sep 12, 2024 | 12:24 AM
Paul...'s Avatar
Smile 2005 C230 kompressor- can I change steering reservoir without removing pump
Hello All,
I looked around and surprised I could not find the answer ...so here goes. I have a 2005 c230k , 140K miles on it and plan to change then steering fluid ... but since there is a filter in the reservoir I would like to change that at then same time (as it must be pretty dirty by now). There are tons of videos on flushing the fluid and or changing the pump / reservoir at once, but can I remove then reservoir without all then trouble of removing the pump too?
Old Sep 12, 2024 | 11:29 PM
Petethepug's Avatar
90 VW Corrado g60, 07 New Beetle Vert triple white & 09 Escalade ESV Plat LOL!
Subscribed on this …
Old Sep 12, 2024 | 11:36 PM
slammer111's Avatar
2003 C230K Coupe Orion Blue
I would imagine the reservoir and pump are connected by 1 or 2 hoses, with corresponding hose clamps.
Old Sep 13, 2024 | 03:42 AM
112233's Avatar
w203cl
Looks like the reservoir is directly attached to the pump.
Old Sep 13, 2024 | 10:02 AM
KevinH2000's Avatar
2005 C230 Sport Sedan-6 Speed Manual
The video shows a C320 which may have a different pump and reservoir configuration.
Old Sep 14, 2024 | 11:33 PM
Paul...'s Avatar
Yes, you are right ... confirmed at then dealership ... to big a job ... I will just flush it ... thanks
