My car was bleeding.
Old Nov 26, 2004 | 06:21 PM
LeifW's Avatar
2005 C230 Sport Sedan w/Automatic
Well I came home this past Wednesday and I noticed a spot of liquid on the garage floor. I looked under the car (2005 C230 Sports Sedan w/2100 miles) and saw what looked like blood dripping from underneath. You guessed it. I experienced the transmission leak that seems to be common with the 2005 C-Class. I called my dealership and brought the car in this morning. I brought some printouts from this forum, which discussed the problem, to the dealership in case they were not familiar with the issue. It was not necessary. My service advisor was very familiar with the problem. It took them about ½ an hour to fix the leak and wash the car. In case anyone is interested, here is what was listed on my invoice:
“Found trans electrical plug leaking. Replaced O-rings & modified old plug per P-B-27.00 ”
Does anyone know what “P-B-27.00” refers to? I imagine it is some sort of Mercedes bulletin. I’ll monitor the car to make sure the leak is fixed. I just thought I’d post my experience for others to read.
Leif W.
Old Nov 26, 2004 | 07:39 PM
pickupjason's Avatar
C230 K
the same thing happened to my wife's 2004.5 C230K..
Had the car towed to the dealership...the service advicer said he saw most of this case happens on 03 or before C-class and he also said that Mercedes had a new parts for that. However, it still happened to my wife's 2004 and ur 2005...
Old Nov 26, 2004 | 09:07 PM
hanke's Avatar
Leif,
Is yours Automatic Trans or Manual?
Old Nov 26, 2004 | 09:42 PM
jan ken po's Avatar
'05 SS Brillant Silver
Happen to mine about 2 weeks ago.....my dealer had to ordered a new "plug", no mention of the o-rings though, hmmmmm. As of today, it is still "bleeding".
Old Nov 26, 2004 | 10:06 PM
mick1's Avatar
2005 C320wz
did you guys take the car in for the 1k mi check up ?
is this something that the dealer could find when they perform the 1k mi inspection ?
thanks.
Old Nov 26, 2004 | 11:44 PM
jan ken po's Avatar
thanks.
Yep, I did. It past A'ok. Don't know if my dealer checked for this specific prob or not....the way they seem to be so far, I'm going with "no." I'm at 5300 miles.
Old Nov 27, 2004 | 01:13 AM
BabyBenz6spd's Avatar
2005 C230 Sedan 6spd
Auto or manual?
Old Nov 27, 2004 | 09:45 AM
cntlaw's Avatar
C55AMG W203; 330i E90
me now
it happened exactly the same bleeding when I returned home after a trip I did not drive the car for 2 weeks!
So what will happen if I don't get it fixed?
cnt
Old Nov 27, 2004 | 11:03 AM
jan ken po's Avatar
cnt
Are you serious?? Just stop and think about what exactly will happen when all your TRANSMISSION fluid leaks out.
@ Baby: Auto
Old Nov 27, 2004 | 11:40 AM
LeifW's Avatar
To all,
I should've specified that I have an automatic. Also, I had brought my car in for its first complimentary checkup about 300 miles ago. Everything was normal at that time.
Leif W.
Old Nov 27, 2004 | 12:12 PM
My_C55's Avatar
S63, 560SL
Its a known issue on 05 model w203's.
The dealer will replace the faulty o-ring and away you go. (mine's had this done already as well.)
The other small issue w/ 05's is the rattle that comes from the trunk release button if you have music w/ bass. Again the dealer will replace and insulate the switch and problem solved.
Old Nov 27, 2004 | 12:30 PM
Turbo2's Avatar
Is "P-B 27.00" the service bulletin for this? If so, I will just make sure to inform the dealer at my first service A to do this, thanks.
We should compile a list of Service Bulletins for '05's, anyone know of any others?
Old Nov 27, 2004 | 12:41 PM
mick1's Avatar
2005 C320wz
hmmm... if this is a common problem, i wonder why there isn't a recall campaign to address the problem .
Old Nov 27, 2004 | 02:59 PM
My_C55's Avatar
S63, 560SL
I dont think they feel its serious enough for a recall, its more of a TSB, so if a car comes in w/ this symptom they know what to do to fix it.
Old Nov 27, 2004 | 04:09 PM
LeifW's Avatar
My_C55,
I too have the rattle from the trunk release switch. Do you know if they have to take the door panel apart to fix it. I'm concerned that they might introduce some other rattle when they fix the button.
Leif
Old Nov 27, 2004 | 04:25 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Anyone know how to check the tranny fluid?
I'd like to check mine...
(Automatic)
Old Nov 27, 2004 | 05:04 PM
i7iceguy's Avatar
2010 E350, 2007 S550 - SOLD, 2007 ML350
i had a similar problem with my 05 230k.. i took it in for a complimentary fix but a monther following the fix, the transmission fluid started leaking again..
i have to take it in yet again..
Anybody familiar with the lemon rule?
Old Nov 28, 2004 | 01:40 PM
My_C55's Avatar
S63, 560SL
Originally Posted by LeifW
My_C55,
Leif
I dont know if they have to take the whole door panel off. I dont think so, I'm pretty sure that the window/trunk module pops off
Either way even if they did take off the panel for me it works:
Before = RATTLE... After = Silence!
Just tell them its a common issue and that they need to replace and insulate the switch.
Old Nov 30, 2004 | 08:48 PM
jan ken po's Avatar
Damn...2 weeks today, and still no call on this "plug". how long does it take to order a damn plug. Somebody is getting an earful tommorrow.
