First MB C230
Old Sep 20, 2024 | 06:59 PM
Johnr64's Avatar
First MB C230
My son got a 2003 C230 sedan with a 1.8l supercharger. it has a oil leak and he can't drive it because he says his knees hit the under dash so he asked to swap for the 2013 Cruze I used as a daily driver. I've never owned a European car. This one has a leak and a bunch of warning lights. I've got a couple of different bi directional ODB2 scanners but they don't seem to work well with European makes. What is the best economical scanner for this make?
Old Sep 20, 2024 | 07:25 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W203 forum...
Old Sep 21, 2024 | 02:24 AM
slammer111's Avatar
2003 C230K Coupe Orion Blue
There are a pile of known leaks for your car. The good news is they're all relatively easy fixes.
Oil will leak from the vacuum pump in the back, as well as the cam sensors in the front (there was a recall for this). Both are easy fixes.
Coolant will leak because the plastic coolant pipes crack. There are 3 pipes and 1 nipple that are known for doing this.
The DIY sticky at the top of the W203 forum will have all the required links. Your engine is M271.
Old Sep 23, 2024 | 12:34 AM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
If you were expecting an easy inexpensive car to maintain well....
So where's the leak? Can I buy a vowel?
Give us a clue.
As far as scanner, I don't recommend iCarsoft
I have one, but most of the codes I get it says aren't supported.
I'm actually wanting to know the same thing.
It does however quite a bit of info in the live data section
is able to read all the systems in the car so thats helpful.
But i can't clear an SRS error after going a steering wheel swap.
Very frustrating and no one around here has Star Diag.
Old Sep 23, 2024 | 12:20 PM
mgbenz13's Avatar
2005 c230 Sport Sedan
Thanks buddy! Needed that! First timer her also
Old Sep 23, 2024 | 05:58 PM
Petethepug's Avatar
90 VW Corrado g60, 07 New Beetle Vert triple white & 09 Escalade ESV Plat LOL!
Welcome from SoCal. Did you get a sedan? How tall is your kid?
Old Sep 23, 2024 | 09:55 PM
Johnr64's Avatar
Thanks, it's a C230 4 door Sedan. Has lots of matainence items to take care of.
​​​​its was idling sort of then chugging I had to feather it to keep it from dying. I took off the air cleaner and MAF sensor holder. That hose clamp at the bottom needs experience to remove and replace but I got through it, although it must have taken me a good 40 mins with long nose pliers to remove and then a wire clamp to put it back. I was going to use a zip tie to hold open the clamp but the wire clamp works fine. It's easier just to pull the clamp up into position while wide open by feel rather than by sight. I used an entire can to clean out the sensor. I'm not sure out it gets the oil in there. I didn't see a breather cover on the back of the block, is it built into the valve cover with an oil seperator on this engine? It's losing about a ton of oil what are the most likely culprits? It idles fine but now my dash has lit up like a Christmas Tree.
My son is grown and 5'-7" small guy. Compared to me at 5'-11"
Old Sep 24, 2024 | 10:16 AM
an6dk's Avatar
2002 mercedes c230 kompressor coupe (CL203)
i think your kid saw all the problems and said no thanks lol, Im 6"5 and am pretty comfortable in mine. as far as the leaks you dont need to worry too much about them for the most part, as others have said theyre most likely the known leaks for this car and should be an easy fix. what warning lights are you getting and what symptoms do you notice while driving that could be related to warning lights? If you have lights but the car works perfectly its very possible that the lights are from something that the previous owner fixed and didnt clear the code for. My car had a misfire code and I ended up tearing the engine down to the block and reseating new valves and surfacing the block and head and I still had that same misfire code for about 6 months after I fixed the low compression, maybe take it somewhere and see if they can clear the codes then drive it and see which ones come back to know what is actually wrong.
Old Oct 1, 2024 | 09:23 AM
an6dk's Avatar
theres an oil seperator on the passenger side of my engine, i have a m111 so its got the supercharger and intercooler which seem to keep oil out of my maf. Have you tried putting some paper under it and parking it for a few days to see if the oil is leaking out. If its not then Id guess youre burning oil, its in the coolant, or its leaking into the car. Id say look for drips then watch it run to see if the exhaust looks smokey (that can mean burned oil) and make sure your coolant looks normal. If that doesnt find you the issue you might want to do a compression test to see if there could be an issue with sealing, not sure how likely a compression test is to help but its not too hard to do and can give you valuable information about what the engine is doing and while youre in there you can check the spark plugs and you may notice some harder to spot leaks under the cowlings you take off to get too the sparkplugs.
