EIS / electronic steering lock (ESL) failure
Wondering if anyone has dealt with this. The car decided to stop recognizing my key fobs intermittently. Started one afternoon, and was completely dead the next day.
My 2nd key also worked intermittently before everything stopped working it's not the fobs. Must be the EIS (electronic ignition switch) or the ESL (electronic steering lock).
Called the dealer, and was told the EIS is a theft related part (TRP), which means that a) the car has to be towed in, and b) they have to do the work. Makes sense, as the modules are tied to the VIN and aren't fungible without extra coding. However, for TRP, proof of ownership (such as insurance) isn't sufficient.
1) anyone know how to definitely identify if it's an EIS failure as opposed to ESL? My logical guess is EIS, but would like to hear another opinion.
2) Anyone have experience getting the EIS or ESL repaired/replaced by a 3rd party? I'm probably going to go this route as the dealership price is absolutely insane. If so, any specific businesses you can recommend? Apparently some places can either a) bench repair the device, or b) clone it into a 2nd (donor) module.
At the end of the day, I just want a working car.
At the dealer, getting EIS replaced will be pricey.
Are you good at soldering? Many times it is a cold solder joint or two that takes EIS out. Just refreshing the solder can solve some of these issues.
ESLs usually fail due to small motor inside crapping out.
ideally you get codes read on a machine that speaks Mercedes. Should be able to narrow it down to one or other.
With the steering wheel in low position you have enough room to get it out.
Car starts. Both keys are recognized. Doors remote lock and unlock.
Everything works except my car now throws some light sensor error. I know this error can be caused by a bad battery or voltage regulator, but a) the battery voltage looks fine, and b) this problem wasn't there before I removed the EIS.
Light sensor - drive to workshop!
I talked to the guys who did the reprogramming and they said it's most likely an incorrectly coded/configured option, and that it should be a very easy fix for someone who knows what they're doing. Probably something as simple as unchecking a flag. Unfortunately they're not local, so I can't just get them to look at it.
Can anyone with access to Star/DAS tell me the menu path for getting to the light sensor menus, or at least point me in the right direction? Guessing that the car is expecting an input from a (non existent) 2nd light sensor. Thanks in advance.
Like it's soooo serious. You must drive to the werkstat now!
Yeah, so they can milk you for a grand.
Does the car operate ok?
It's an anoyance to have to see that everytime, but maybe no more so than NO PHONE!
I did see some menu's in my new Lauch Elite 2.0 Merc scanner for calibrating the light sensor?
I wonder if it could be as simple as that?
BTW- what was the shop? Sounds like a good resource.
All is well. Back on the road.
Looks like all of the shops that can program/clone W203 EIS modules are located in USA. I was unable to find one in Canada willing to take on the job.
The shop I used was The ECU Pro based out of Wellsboro, PA. Very professional. Great support and fast shipping (within USA). They definitely know their stuff. I am a happy customer.
FYI they also provide services for other modules (ECU etc.), as well as other German makes. Mail in whatever module and they service it and mail it back out. Pretty good business model actually. There is definitely a need for this service out there.
Nothing critical broke last year though, so it's hit and miss.
