Ticking noise from behind cluster
2019 Mercedes Benz S500L AMG Premium Plus
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
I have started to get a ticking noise from behind my instrument cluster that goes away momentarily when the brake pedal is pressed. This happens both whilst stopped and on the move. Anyone else experienced this?
2001 c320 - 2002 ml55 - 2011 c300 - 2014 slk350 - 2015 cla45
ive experience a ticking noise also... mines only on the move.... steering column.. cluster area... somewhere behind the steering wheel... had the car in the dealer the other day, but as youd expect.... sounds was not reproducable......
Thanks. If you make any headway, I'd be grateful if you could update this thread.
2005 Volvo S40 T5 AWD, 2004.5 C230 Sport Sedan, 2005 E320 CDI, 2008 C300 4-Matic Luxury
There is no ticking noise at all coming out of my instrument cluster, but if I did have noise and was curious to see/hear what was living back there I would remove the instrument cluster and see for myself. You'll need to buy a the instrument cluster removal tools at the MB dealer (about $15) and pull it out. My neighbor had a mouse living in his, chewed through the cruise control wiring while driving. Finally trapped it with a lot of traps.
2005 C240 4Matic
Ticking Noise
Got my 240 2 weeks ago, feel as if the ticking is coming from the glass covering the instrument cluster...maybe a little loose...going over bumps in the road it is slight, when I crank the bass on the stereo it really starts ticking...
The noise I had is at a steady rhythm. At first I thought it was a label on a CD hitting off of something as it spun round. I eventually eliminated that togethr with heater fan. It got really strange when I found out it went off when I pressed the brake pedal. I have even managed to replicate in with the key in POS 2 with the engine off.
Brabus K3
Have you solved it?
Best Regards.
2013 c300 4matic, 2002 c240
I found this answer on the net:
What It Is, Is A Electric Stepper Motor That Is Going Past It's Stop, Because Linkage That Connects It To The Hvac Flap Is Broken. The Most Common One To Fail Is The Footwell Flap Motor/linkage. This Is In Ignition Switch Area. Mercedes Offers Newly Updated Linkage Not So Prone To Breakage. Other Stepper Motor Positions Fail As Well, But It Is The Footwell Flap Motor/linkage 80% Of The Time.
Brabus K3
Best Regards.
Yes, even with the air off. Seems that when starting the car a computer moves the flap to find where is, then it moves it where the front panel switches tell it to go.
Brabus K3
Then I have the same problem and it's doing it anytime. When I start the car, after 45 seconds, after 30 seconds, after 2 minutes, after 15 seconds, etc....
Best Regards.
Best Regards.
2005 C230K SS-Red on Black Leather
Hi, I'm new to this forum. Just got my '05 C230 a few days ago. I just noticed there's an itty bitty piece of wood (
![crazy](https://mbworld.org/forums/images/smilies/crazy.gif)
![Mad](https://mbworld.org/forums/images/smilies/mad.gif)
