Help!!! Please Read! Ticking Sound!
I NEED HELP! My son's C320 was outside, and i walked by it and there was a constant ticking/chirping sound right behind the the right front tire.... its coming from under the car, but the the damn thing wont stop, the car was off, and it kept chirping and ticking, it even chirped and ticked when we were driving it! HELP!!!!!!!
are you talking of a constant tapping noise? you may have already seen this but it may be the purge valve that needs to be replaced... have you done that...
and when u say it does the same thing when the car was off, is it the normal ticking u hear from a car.. i have heard a ticking noise coming from cars immediately after htey ahve been turned off..not really sure what it is but it stops ina few mins... it's not a constant ticking....
Sounds like a cat - when you shut the engine off, it begins to cool down and its housing produces this tickling sound for quite a while as a result of a thermal contraction.
guess what it was? i guess i pressed the panic button, and the ticking stopped... that was soo wierd.... and guess who told me.... a truck driver at a local gas station... who knew?!?
I have the same problem. that constant ticking noise coming from somewhere in front, when car start to move or even on highway. went to see dealer, and they said they have to take out whole front dash to see what the problem is.
how can you stop that noise when car is in motion? (panic button goes into key hole)
thanks.
thanks.
i'm not sure i understand... is that an alarm or something that you guys are hearing... i thought presseing the panic button sets the alarm off.. i have tried it just for fun and won't shut off till the key is in the ignition...
so carter when u pressed the panic button, the noise went away?? wonder what it was in the first place.....
