Aftermarket Wheels Fitment (W204)
Old Aug 28, 2007 | 10:54 AM
bjafari84's Avatar
Anyone know the wheel specs for a c300? I'm looking to buy either 18" or 19" wheels but have no idea about the offset...
Thanks!
Old Aug 28, 2007 | 10:55 AM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Yes,
I posted a listing of those based on available MB wheels.
Old Aug 28, 2007 | 10:56 AM
bjafari84's Avatar
Originally Posted by amdeutsch
Yes,
Could you direct to me that post, I tried searching, but I could not find any answers. Thanks!
Old Aug 28, 2007 | 11:48 AM
trustz's Avatar
2010 W204, 2014 W212, 2015 W222, 07 SAAB 9-3, 2016 AMG GTS
you need offset higher than +45, so those wheels fit on W203 will NOT fit on W204 !!
Old Aug 28, 2007 | 12:27 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Did you use the advanced search feature? It makes it easier next time you have to search.
Thread link
Old Aug 29, 2007 | 12:27 AM
aowhaus's Avatar
2008 C300 Sport 4matic
Spacers would allow wheels of a different offset to be mounted with enough clearance for the calipers.
For example if you want to use wheels of an offset of 38 on a W204 (offset 45 to 50), you will need a wheel spacer of at least 7mm to correct the offset. As long as your wheels are no wider than 8.5" you should be fine.
Old Aug 29, 2007 | 04:47 AM
V8 AMG's Avatar
2008 C300 Avantgarde
Here are the specs for both 17 and 18 inch wheels....
Front ....17 X 7.5 ET47 with 225/45/17 tires
Rear..... 17 X 8.5 ET58 with 245/40/17 tires
OR
Front .... 18 X 7.5 ET47 with 225/40/18 tires
Rear...... 18 X 8.5 ET58 with 245/35/18 tires
Old Aug 29, 2007 | 10:49 PM
RLE's Avatar
RLE
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
C300 wheel change
Since I am don't like the stock Luxury wheels, I am toying with replacing them with the stock 17" C350 AMG wheel. The prices are shocking.
Front 7 1/2 X 17 part#B66031400 $735
Rear 8 1/2 X17 part# B66031401 $795
So I called Caliber Motors in Anaheim (1-800-252-6877) that advertises in the MB Star. I have purchased from them before with considerable savings compared to local dealer retail.
Their prices:
Front $602.70
Rear $651.90
Better but still.....
Their cost for the Sport Grill conversion kit (A204 880 0023 9776) is $142.68 vs $171 dealer retail,
