The mirrors don't tilt when you reverse?
#51
2010 E350 SP / Honda Crosstour / prior vehicles - C32 modded / C300 modded / Lincoln LS modded
im interested in what to say to my advisor
If that occurred, and there was no seat memory for the driver's seat, then YES, this can be done. If anyone is interested, I will be glad to send you a link to another site that tells you what to say to your service adviser to get this accomplished. We had it done on our ML320CDI, and our service adviser knew exactly what we wanted and how to get it done. It took no time at all and we weren't charged for it.
And yes, after you drive forward and hit about 10 mph, the mirror goes back to its original position.
You made my day!
You made my day!
#52
Yea, my 2008 C200K does have memory seats and the mirrors tilt when I go into reverse. I'm not sure for the earlier models, but you could program your mirrors to do so. Simply go into reverse, and adjust your side mirrors the way you want it to. After that, drive normally. It should work. It did for me
#53
Yea, my 2008 C200K does have memory seats and the mirrors tilt when I go into reverse. I'm not sure for the earlier models, but you could program your mirrors to do so. Simply go into reverse, and adjust your side mirrors the way you want it to. After that, drive normally. It should work. It did for me ![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
Can somebody confirm that this works? I have a 2011 C300 with premium package (Canada). I would really like auto tilting mirrors when in reverse.
Thanks.
#54
W204 C350
This subject has been beaten into the ground but one last time:
W204s for the United States market do not have memory seats and therefore no mirror tilt down in reverse. Regardless of mirror switch position or anything else.
The fact that other models, past or present may have this feature has no bearing on this question.
http://www.mbusa.com/mercedes/vehicl...350W/year-2011
Please note upper right frame of photo. I pick up mine tomorrow (I hope).
#56
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
I think you may be mistaken about the memory seats. Don't know about the mirrors, though:
#58
I have a C350 with memory seats. To set up the right hand mirror I put it into the proper position and enter it into memory. Then I put the car in reverse and I adjust the mirror downward as I like it. I put this into memory. Now I am set. On reverse the mirror tilts downward and after I go forward at some speed, lets say 10 KM/HR the right hand mirror returns to the normal setting in memory.
It could be that the mirror settings for forward motion and reverse is set at the same position.
Hope this will help.
Jorg
Jorg
#59
2012 C250 Coupe
It will work for anyone not in the United States. However, if you are in the United States you won't be able to enable this feature regardless of having memory seats or not...
#60
#61
Also this feature can be stopped, depending on what position the mirror button was last left in, for the life of me right now I cannot remember which one stops it, if you last leave the active left mirror or right mirror, it's one or the other, prior to putting the car into reverse make sure the red light is on the left mirror, and put into reverse mirror should tilt, if not, put car in park, press mirror button so that the right one is now lighted, and put car in reverse, mirror should tilt...
I never liked the tilting of the mirror so I always had it disabled....
Cheers
#62
Why not ?
Cheers
Cheers
#63
2014 GLK250 BlueTEC, 2012 BMW 335is Conv.
#65
while car is on and foot on brake, put vehicle in reverse, now using the mirror buttons select the right hand mirror, and then move mirror to the most down position it will go, release buttons, hold brake, put car in Park wait a bit, see if mirror moves back up, if not put car into drive, see if mirror comes back to normal position if it does save this into memory, and now try revers gear again and see if it goes down. If not see which button on your mirrors is red and pick the opposite one, try reverse again.
Not everything in the manual works or is available for all models all over the world, they usually make up a single manual, but a multitude of models it could cover.
