Navigation Announcements Do Not Lower The Stereo's Volume
2008 C350 Sport, 2007 ML320 CDI
I'm wondering if my COMMAND system has an issue. When I'm playing an audio source, the navigation instructions just talk right over the music - the music does not fade out or diminish its volume in any way. They just fight each other. I have to take the car in tomorrow because the tele-aid apparently did not get programmed with the correct dialing numbers, etc., so if i have a problem, I might as well get it corrected while it's there.
I read a review on this forum that commented about how well the nav volume integrated with the audio, which led me to believe I have a problem. Does anyone else have this issue?
Thank you for any advice.
2008 Black Out C350 Saks Edition / 87 VW GTI
2014 Ghibli S Q4 & 2008 C350
That would be buggin! I don't want to say for sure, but I thought my salesperson told me it lowered the volume of the stereo accordingly... Definitely worth mentioning though!
2008 C350 Sport / Steel Gray / MM / AMG
The music cuts out when a call comes in over the MM, but nav instructions just talk right over the radio/sat. Yeah...it kinda sucks. I just try to remember not to crank the stereo when I have to rely on the nav.
Wow - what an oversight. Considering that MB's other systems do this, I hope there will be some kind of software update later on that takes care of the problem. I'm going to mention it when I take the car in tomorrow, just to see what they say. Thanks for the feedback.
C180K 2011 COMAND, AMG, Dynamic Xenon, Business Pack, H&K Audio and +
imagine driving in amsterdam with every 10 meters you have to make a turn. Nav sound cutting in every few secs. Example:
Boom Boom --after 50 meters turn right -- BOOM BOOM Bo--- @ the round about make a second exit---BOOM BOOM BOOM --- and so on..
This feaure if added would be so annoying. Yah ofcourse , having the option to turn it on /off would satisfy everyone.
08 C350 4Matic -Premium- Comand NAV-Keyless-GO-Panoramic-Rear Win Sunshade-Memory seat-Quickpark-AMG
Oh that sucks... so if you are blasting your music, the navigation commands will be blasted too? I would rather the music still play while hearing the voice commands.
I know on the lexus GPS, the voice commands talk over the music. But it doesn't get louder or anything when you turn the volume up on the radio.
C3004Matic Sport, Blk on Blk, Pano, P1, MMC, Ipod
another item mb goofed on. Sure, some don't want music cutting out for a nav instruction, but most do and for most its a good feature. But, the easiest way, and not too difficult to figure out or to implement, is to let the user decide. I mean we have this whole command thing with a knob and well developed menu system, what gives?
Yes, as some people have noted, I could just crank up the volume on the navigation instructions which would do nothing but create two, loud, conflicting sound sources. You would not be able to understand either source. Then when I would eventually turn down the stereo volume, the over-enunciating navigation lady would be screaming at me!
I asked my service advisor about it this morning when I took it in to get the tele-aid fixed / programmed properly. He said it will probably be fixed next year, but wasn't sure if that fix would be retroactive.
2011 E350 4Matic Wagon, 2013 C350 4Matic Sedan
The navigation volume is too loud IMHO. And so is the phone ring... freaks the heck out of me.
Why can't there be a volume adjustment on the announcements? Seems like a simple menu item on COMAND. One of the features I miss from the Acura Navi system. I am disappointed about the lack of customization on the MB system.
So... I set the destination, hit the voice control button, and say "Guidance Instructions Off". Then I set the speedometer display to Navi. Peace and quiet.
NAV/audio volume
On my new 08 E-550 the Command Operator's Manual, on p. 110 has a paragraph on adjusting the "fade-out stating that, "Automatically generated navigation announcements are superimposed over any active audio source. The volume difference is adjustable". It goes on to show the NAV screen options ranging from "total fade out" to "no fade out". I've not had a chance to play with this yet and I know my car is not the same as being discussed on this post but perhaps it will help.
NAV/audio volume
Well if that is the case here I would totally agree. I just thought maybe someone was overlooking a page in the manual that explained it but that doesn't sound like the case. I've noticed a few differences in things between the E and S class. The NAV and related options should be the same across all the models. Regardless of the car model a NAV should be the same across all of them - or else give the buyer a choice and sell for less.
No You have 2 sound levels , One for music one for Navigation Voice. You can adjust the music to blast and Navi to be at low level but then you wont be able to hear the Navi voice. I just use the arrows display on my speedometer or sometimes MM screen as well while my music is still at high volume without Navi voice causing any problems as its set to low.
When you hear the navi instructions , while the message is being read example: "after 200 meters trun right" pess the volume down button on your steering wheel. This will lower the volume of the navi instructions only. Not music. To increase it use the volume up button on your steering.
Note: Navigation must be annoucing a message on your route guidence before you can lower or increase the volume.
2005 Volvo S40 T5 AWD, 2004.5 C230 Sport Sedan, 2005 E320 CDI, 2008 C300 4-Matic Luxury
2008 C350
2008 MB C300; 2007 Acura RDX
