Where are the 8 speakers? I only count 6.
Old Dec 21, 2007 | 02:40 AM
JimPap's Avatar
2008 C300 Sport, RWD, US
As the thread title says, where are the other two speakers?
I count what looks like 4 midrange/woofers one in each door and two tweeters one in each front door near the dash. That's only 6. Where are the other 2?
When I change the fader/balance control to the front, I don't believe that there are any speakers in the dash...at least I don't hear any.
What gives?
Old Dec 21, 2007 | 06:56 AM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
MB counts co-axis's as 2 speakers. Therefore your grill count will be off. Could be the ones in the back doors are co-axis.
Old Dec 21, 2007 | 08:09 AM
tanktube67's Avatar
2008 Black Out C350 Saks Edition / 87 VW GTI
What gives?
I believe there are 2 in each corner of the dash, one at the center of the dash 1 at each door and one by the sunshade
Old Dec 21, 2007 | 08:13 AM
JimPap's Avatar
I'm referring to the 8 speaker system. Is that what you're referring to?
Sunshade?...that thing at the back window? Mine doesn't have one there.
Old Dec 21, 2007 | 09:04 AM
tanktube67's Avatar
I have the karman 7 Logic, do you have the standard system?
Old Dec 21, 2007 | 09:30 AM
JimPap's Avatar
P2 with the 6 disk changer, without MM.
Old Dec 26, 2007 | 04:16 PM
JimPap's Avatar
I think your system has something like 12 speakers. Mine has 8 (2 of which are hiding)
Old Dec 26, 2007 | 09:06 PM
430752's Avatar
C3004Matic Sport, Blk on Blk, Pano, P1, MMC, Ipod
for Harman Logic system:
Wish I had a scan of the Harman/Kardon Logic7 system info diagram, but I don't so you'll have to use my words, taken verbatim wherever possible (e.g.: everything but my physical description as to location)
1+2: in each front door, down near knees, is a 168mm metal matrix wide band transducers;
3+4: in each front door, at each side mirror, is a 43mm dome tweeter;
5: at front center dash, behind the nav lcd panel, is a 80mm metal matrix center speaker;
6,7,8+9: in each rear door, at ankles or knees, is both a 43mm dome tweeter and a 168mm metal matrix wide band transducer (same as front, but both in the door now, and seemingly "stacked" like a coax speaker)
10+11: on the parcel shelf, behind the rear seats, one on each side is a 80mm metal matrix surround speaker (same as front center, but two total back there)
12: in the rear, looks like in the headliner (firing down) according to the picture/diagram, but may be on the parcel shelf, is a center-located 200mmx270mm racetrack double voice coil subwoofer.
Electronics: a 450 watt HK DSP Amplifier with discrete logic 7 audio processing synamic equalizing control (DEC) and fully digital, content-protected audio transmission (CTCP) lies in the trunk, on the side, dirver side.
Old Dec 27, 2007 | 12:26 AM
chilledbenz's Avatar
2008 R350 & 2008 C300
Lol I got lost reading the last poster so I'll try to simplify it for you, because its a bit complicated. If you have the standard system the speakers are as follows.
Front Doors: Two Tweeters in the top corners. Two Woofers in the bottom kick pannels.
Rear Doors: Two Woofers in the bottom kick pannels. Two tweeters in the bottom kick pannels (get a flash light out and shine in you will see the tweeters in front of the Woofers).
*Of note, the center area on the dash that would appear to be a speaker location isn't one in the standard system.
Old Dec 27, 2007 | 02:46 AM
JimPap's Avatar
Thanks....mystery over. Now where did I leave that flashlight. lol
Old Dec 28, 2007 | 02:41 PM
Ha ha thats ok, I had to go do a double look myself. There are spots for tweeters in the rear doors at the top hand corner, but once I shined a light there, there weren't any holes. Location used for the Multi Media package and not for standard radio, so then I shined in the bottom speakers and sure enough, thats where the tweeters are. Why they didn't use the top locations is yet another MB mystery.
Old Dec 28, 2007 | 02:43 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Nudge, nudge, hint, hint, post #2 of this thread. Also confirmed by previous W203 threads.
Old Dec 29, 2007 | 11:43 AM
paigelinks's Avatar
c300 Sport P
Audio System - disappointed?
I was just reading the posts about the 8 speaker mystry. I also could not find the 8 speakers and had just called MB when I found your postings. They want me to bring it in so they can check as I thought 2 were missing. Thanks for clearing that up for me.
I have not been satisfied with my standard audio system. I did not opt for the mm package as I thought the sound system would be fine for me - and expected a quality system from MB. Otherwise I would have opted for the MM option.
Is anyone else find the system lacking in clarity and enough bass? If so, what is a remedy for this. I am uneducated in the car audio sound system area. I am going to take it back to MB to see if there is something wrong with my system, but in the event i am told it is fine - what are my options and do I have to have MB do the upgrade?
I previously had a Land Rover LR3 with LR's "standard" harmon-karman system. I am just looking for a comparable sound.
Thanks.
tpc
Old Dec 29, 2007 | 11:56 AM
W0n6_3d4n's Avatar
C200K (w204)
Clarity and bass is an issue in the HK package, but the sound staging and imaging is rather good (the logic processor does wonder).
I suspect the speakers they use is the culprit, 6x9 for bass module?? oh please...
Old Dec 29, 2007 | 12:19 PM
JimPap's Avatar
Originally Posted by paigelinks
...snip...
Is anyone else find the system lacking in clarity and enough bass? If so, what is a remedy for this. ...snip
Time.
Its takes about a month for the speakers to shift enough where you start thinking that its not all that bad. At three months, it'll sound pretty good. I boosted my bass and treble early on. I had to turn those down as they're too much now.
Old Dec 29, 2007 | 12:58 PM
paigelinks's Avatar
c300 Sport P
Time.
Seriously..... I have treble and bass boosted and did that at the onset.
When you say "for the speakers to shift" what do you mean? As i said, i am uneducated in audio systems.
Old Dec 29, 2007 | 01:07 PM
JimPap's Avatar
To break in such that they more accurately reproduce the sound intended without distortion.
Old Dec 29, 2007 | 01:38 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Thanks.
tpc
Therein is the issue. In the LR case you had an upgraded system, HK, as standard whereas in your MB HK is an option.
Old Dec 29, 2007 | 06:06 PM
paigelinks's Avatar
c300 Sport P
So, are you saying that in 3 months I will just get used to the sound system and accept it, or is the sound quality really going to change. I have never heard of such thing.
Thanks.
Old Dec 29, 2007 | 06:18 PM
JimPap's Avatar
r u serious?
Old Dec 29, 2007 | 07:54 PM
W0n6_3d4n's Avatar
C200K (w204)
Speakers do need break in period as they are a moving mechanical part, however the shift will not be great, what usually happen is the ear will be the one that adapt to the sound and will find the sound 'acceptable'. Other important thing to note is, it's in a car environment so any change in the sound will be hardly noticeable.
Old Dec 30, 2007 | 12:06 AM
JimPap's Avatar
Hardly noticeable...only if you're deaf.
Old Dec 30, 2007 | 05:02 AM
W0n6_3d4n's Avatar
C200K (w204)
I'm far from deaf. My Dynaudio split play beautifully in my old car, i didn't hear anything drastic from the moment i installed it until i sold it. The only thing that was noticeable is the tweeter, which smooth out a bit and even then i suspect it's my ear who's doing the adjustment. Same story with a Scanspeak + Eton system in my cousin car i helped design, it does not differ in term of accuracy nor sound quality over a period of time.
You will hear it in home environment, that's for sure (my Avantgarde speaker open up nicely after few weeks of playing), but there's too much noise in the car to notice massive difference. Just my opinion, if you do hear the difference, good for you.
Old Dec 30, 2007 | 07:46 AM
JimPap's Avatar
With all due respects, you're not relating to the speakers in the 2008 C car. ...and each speaker/manufacturer has its own characteristics that may or may not transfer to other speakers. To presume that these speakers don't improve over time because other speakers that you have experience with didn't isn't a valid assumption.
There is a simple solution as we're obviously not going to agree.
Just give it time and if in two or three months the owner doesn't like what they hear, they can rip it out and put something else there.
On a related matter, some of Sirius radio channels have limited dynamic range probably from compression and as such won't sound nearly as good as a well mastered CD. Try some CDs to see if they don't sound better.
Old Dec 30, 2007 | 11:22 PM
IgorDj's Avatar
'13 C300 '14 E63S '08 E92 M3
i was wondering does any also have the problem with the back speakers in the back seats, there is one giant speaker in the back split intlo like 3, but no sound comes out when i adjust the sound to come out from the back, only sound comes from the 2 passenger speakers on the doors.
