Squeak when folding electronic Side mirror
Old Jan 28, 2008 | 01:53 AM
lx Raven xl's Avatar
C180K 2011 COMAND, AMG, Dynamic Xenon, Business Pack, H&K Audio and +
I have noticed a squeak in passenger side "Side rear view mirror".
I started noticing it after a car wash yesterday while folding and unfolding the side mirrors.
What are the chances its just some water left inside the mirrors joints? It does not sound like there is a problem with motor. Sound definatly comes from joints of the mirrors like some surface is rubbing against each other while they are wet. Think about a sound when you rub your finger over a wet pastic.
Anyone got this problem. I am gonna get it checked in few days if the sound stays there.
Old Jan 28, 2008 | 04:36 AM
DJ Kyro's Avatar
C200K '08
i heard it too. it's on my passenger side mirror.
Old Jan 28, 2008 | 04:41 AM
Yah only on passenger side... Mine started to make noise after the car wash.
I dont go to automatic ones. I just hand wash the car.
I am gonna fold them in opposite direction ( You have a button to do that ) and check if theres water under the joints. Will post here if the sound is still there. I will get them checked too if the sound remains.
Old Jan 28, 2008 | 05:23 AM
W0n6_3d4n's Avatar
C200K (w204)
Same here, mine hasn't been washed in weeks nor has it been raining. Happened twice.
Old Jan 28, 2008 | 07:58 AM
ni2mi2's Avatar
C300 Sport
Hmmm...Is that something on the European models? I dont recall anything like that on the US W204s!
Old Jan 28, 2008 | 08:36 AM
PoaMike's Avatar
C300 (W204) w/ MM, P1, & 18"amg's
Iv also noticed the same noise. Its is on the driverside, I think it happens when you walk awayfrom the car with out locking it and the car autolocks so the mirriors dont fold in but maybe the car thinks they should? Just an idea have no proff or anything.
Old Jan 28, 2008 | 08:57 AM
Not sure for US model but yah in my car there is a button which fold the mirrors in opposite direction.
And i get the sound everytime i fold -unfold the mirrors. Doesnt matter i use the key to lock the car or it auto locks or i press the button to fold unfold mirrors. I have'nt checked yet folding in opposite direction but will do so after work.
Myabe its just water in there thats making the rubber to make a sound when they rub against each other. I hope so.
Old Jan 28, 2008 | 09:02 AM
PoaMike's Avatar
Well it seems that we are all having some sort of 'sound' so i would worry to much since its a large group of people hearing the same thing. Still if you find out keep us posted!
Old Jan 28, 2008 | 09:14 AM
The squeak sound was not there before yesterday so i see it as a defect. I will keep you guys posted.
Old Jan 28, 2008 | 09:22 AM
PoaMike's Avatar
O i miss understood, its happening all the time now. Thats not the same problem as it seems most of us are having. Ya I would go to the dealer and demand an explination.
Old Jan 28, 2008 | 10:04 AM
am2121's Avatar
2008 C350, P2, MM, 18" & 2007 C280 4matic
I had same issue but on the drivers side 3days after getting my car. Took it to dealership and they resolved it in 10 mins. Not sure what they did but not occurred since.
Old Jan 28, 2008 | 10:15 AM
i m gonna check again. if i cant fix it then I will take it to the dealer as well.
Old Jan 28, 2008 | 03:22 PM
chilledbenz's Avatar
2008 R350 & 2008 C300
They probably just sprayed some sort of silicone on it to stop it from squeaking. On a second note all my door handles squeak when I pull on them to open them, so its probably just a plastic on plastic sound, same as the mirrors.
Old Jan 28, 2008 | 05:03 PM
Hungy's Avatar
I drive 2008 C350
Yea mine squeaks too on the driver side. But i think it only squeaks when the weather is cold. I will try again because just that i stop folding it since it keeps squeaking.
Beside that my driver seat squeaks too everytime i sits down or move around or even when i go through bumpy road.
Old Jan 28, 2008 | 10:44 PM
Savage c-300's Avatar
C300 Sport, MM, P1
+1 my passanger side squeaks as well. i have the auto fold feature on. i only hear it when im by my passanger side door so it doesnt bother me. if everyone else has this issue, i guess its normal. post your dealership results if you guys take it in.
Old Jan 28, 2008 | 11:01 PM
oblu's Avatar
c300
Squeek? Both mine screech in protest as they fold or unfold. I'm leaving them set to fold in hopes that they'll finally fail so the dealer will be forced to fix.
To be perfectly honest though (this happened long after they started screeching) I've had them freeze in the closed position before because I was parked outside overnight.
When I first complained about my mirrors vibrating over bumps, at speed on the highway and when closing the door the dealer tried fixing them; they claimed that there is a service setting to set how far they open and close.
Mine are so loose now that I can physically wiggle them like a kid's loose tooth that just won't let go. I'm sure that has a lot to do with the screeching noise.
Old Jan 28, 2008 | 11:35 PM
rb23lb's Avatar
LOADED 08' C350 & 14' GLK-350 Diamond White (P1, MM, AMG Pkg, Ln Trkng, Htd Sts, Keylss Go)
I also have this same sound on passenger mirror as well as with the door handles, and have posted on it before...
NOTHING SERIOUS, JUST MEANS THE JOINTS FOR BOTH NEED LUBRICATION AT YOUR NEXT SERVICE...
IT IS A DESIGN FLAW, BUT NO BIGGIE!
Old Jan 29, 2008 | 02:40 AM
C300 Sport, MM, P1
good to hear, ill make sure they give it a little lube next time i take it in.
Old Jan 29, 2008 | 02:45 AM
Ok. well as i said my squaking started after the crash wash. It was only for the passenger side mirror while folding unfolding. But today the sound was gone! so its back to normal. How i fixed it?
Well I did not do anything special. I went to me car , unlocked it. opened the door , heard the squeaking sound. Started the car , started driving to work. I had to adjust my passenger side mirror. after adjusting it and reaching my destination, I locked the car and as usual was expecting the squeak, but there was none!!
so adjusting the passenger side mirror fixed the squeak.
There is no other squeaking / rattle sound I hear from handles, side mirrors, doors etc etc even at high speeds. The car feel very reliable and comforting and solid.
Old Feb 1, 2008 | 08:47 AM
tanktube67's Avatar
2008 Black Out C350 Saks Edition / 87 VW GTI
take it to MB dealer they will lube the mirrors at the spot
Old Feb 1, 2008 | 10:07 PM
spotless's Avatar
C300 Sport
sounds very naughty and i like it
Old Feb 2, 2008 | 05:12 PM
aansonsit's Avatar
08 C350 4Matic -Premium- Comand NAV-Keyless-GO-Panoramic-Rear Win Sunshade-Memory seat-Quickpark-AMG
CANADA CANADA ..............same problem!! suck mirror
Old Feb 2, 2008 | 06:11 PM
aansonsit's Avatar
use WD 40 .....work?
Old Feb 3, 2008 | 01:59 AM
aansonsit's Avatar
why only passenger side mirror hv problem , driver side...still fine
Old Feb 3, 2008 | 04:25 AM
DJ Kyro's Avatar
C200K '08
I agree it might be in the cold.
