Made a mistake aiming fogs
Old Apr 7, 2008 | 04:17 AM
Lakerz4sho's Avatar
c300 sport
Ok so, I turned the screw that aims the foglight, and i guess I turned it all the way to the maximum position (pointing up from default position). In my efforts to turn the screw the other way, I ended up stripping that torx screw so I can't even turn it at all anymore. The Mesh piece doesn't fit flush with the foglight out of position. Is there any way to fix this problem and point the foglight back down to the factory default position?
Old Apr 7, 2008 | 05:29 AM
micropower99's Avatar
2008 Mercedes C300 4Matic
Why did you change the aim of the foglight in the first place? (Did you do it accidently from changing the bulbs or intentionally?)
Old Apr 7, 2008 | 10:01 AM
tanktube67's Avatar
2008 Black Out C350 Saks Edition / 87 VW GTI
Old Apr 7, 2008 | 10:40 AM
mac911's Avatar
C300 Sport/Palladium Silver on Black/P2
Don't know where you live, but hopefully it's somewhere without much fog or rain, so leave them off, for now.
Old Apr 7, 2008 | 11:41 AM
jo17jC230's Avatar
2008 C300 Sport
If the torx screw is stripped then most likely you are screwed and have to get a new fog light.
Old Apr 7, 2008 | 12:32 PM
Lakerz4sho's Avatar
c300 sport
yes, i'm a moron and i started unscrewing the wrong screw trying to remove the foglight grill.
Old Apr 7, 2008 | 03:38 PM
chilledbenz's Avatar
2008 R350 & 2008 C300
Go the the hardware store and buy an easy out, its a bit that will screw into the stripped head of the screw and allow you to remove it. Then go to the service department at your dealership and order up a new screw, problem solved.
Old Apr 7, 2008 | 03:43 PM
Derspeed's Avatar
X3 and 2012 C coming soon
Unless he stripped the threads. If that's the case, buy a tap and a slightly bigger (thicker) screw. Then, stop messing with the lights.
Old Apr 7, 2008 | 05:25 PM
jo17jC230's Avatar
2008 C300 Sport
The problem is that part is not a screw that you can just take out and replace it with a new screw. It's more of adjustment knob that needs a torx wrench to turn the knob. That part is plastic and used for adjustment only. It's not meant to be overturned in either direction.
Old Apr 7, 2008 | 05:49 PM
tanktube67's Avatar
Go to dealer parts department, explain what happen. I'm sure you'll have to purchase a new screw with the adjustment plastic insert and keep the fog lights off by meantime, and by screwing things up that’s how we all learn, good luck.
Old Apr 7, 2008 | 07:24 PM
QQQ's Avatar
QQQ
MY2001 C320
He has the virtue to admit he is a moron... that said I have nothing to offer. Good luck.
Old Apr 8, 2008 | 03:08 AM
narky's Avatar
2008 Arctic White C300 Sport 6M
This is something I would do. I was thinking about hardwiring a navi. What if I fry a circuit board or something?
