Staggered setup for 4 matic
Old May 3, 2008 | 12:32 AM
joe07328xi's Avatar
08 C300 4matic 07 BMW E92xi
Hi
Is it ok to run staggered setup for my c300 4matic?
Old May 3, 2008 | 07:56 AM
andy_meng1024's Avatar
2003 SL55, 2010 C63
Yes, as long as the overall diameter for the fronts and the rears are not off by too much.
Old May 3, 2008 | 09:27 AM
jangy's Avatar
2015 S212
I'd actually be careful about that. the AWD system doesn't just feed off of rotational comparisons, it also gets feedback from traction. Wider fronts will fake the system into thinking that the rear is loosing traction. Where I noticed the worst reaction (in an E 4matic) was on diving into turns. The car would lean forward hard then think that the inside rear was sliding so ESP would kick in. It really made me slower, eventhough I put wider tires in the front. I'm sure it can be done properly, but do your research so you'll be happy with the final.
Old May 3, 2008 | 11:31 AM
06Benz230's Avatar
2008 C300 Sport & 2008 E320 Bluetec
I thought the C300 4matic already had a staggered setup when you buy the car, mine has 17x7.5 22/45/17 and 17x8.5 245/40/17???
Old May 3, 2008 | 11:35 AM
QQQ's Avatar
QQQ
MY2001 C320
C300 4Matic sport comes factory equipped with 225/245 17in wheels.
Old May 3, 2008 | 11:36 AM
06Benz230's Avatar
Thats what I thought, that's why I didn't understand what he was asking in the first post.
Old May 3, 2008 | 12:11 PM
QQQ's Avatar
QQQ
MY2001 C320
the 225 front is 45 and the 245 rear is 40. So the front tire walls are 101mm thick and the rear 98mm or 6mm (0.24") difference in diameter. So the perimeter of front and rear wheels are 78.4" and 77.6" respectively, or roughly 1 rotation difference for every 78 rotations. Unless the ESP has a very low tolerance this should be OK.
In reality the 40 and 45 are approximation (likely both tire walls are 4" or 101.6mm), which translates to 45.2 for front and 41.5 for rear and tire manufacturers just use 45 and 40 as proxy.
Old May 3, 2008 | 01:54 PM
vcruiser's Avatar
2013 G63 AMG
i have a c350 4matic with the optional 18'' AMGs and theyre sttaggered
so its from the factory..its ok to have staggg
Old May 4, 2008 | 05:00 PM
extassy's Avatar
'06 M5, 08' C300, 02' WRX
Originally Posted by joe07328xi
Hi
Dude... you gotta use the SEARCH button!!!
https://mbworld.org/forums/c-class-w204/242182-c300-4matic-wheel-size.html
