Door lock pins-AGAIN
#76
https://mbworld.org/forums/showpost....6&postcount=23
#77
2008 C-350 Palladium Silver and MM.
Someone else mentioned using air hose from a fish bubbler inserted into the back ones to make them fit tight onto the little knob. If they are almost flush when locked, that should prevent people from pulling on them.
#78
Hope this explains everything clearly enough.
https://mbworld.org/forums/showthrea...461&highlight=
#79
05-350slk and 08-c350
#80
If you are willing to cut the tops off of your lock pins to make them flush go ahead. The solution provided is the best available without destroying your car and this was a solution for a "safety defect" since if the pins pull off- you can't open the door. Good luck with your decision.
