Euro lock pins
Old Jun 12, 2008 | 06:10 PM
AkaSigFreak's Avatar
E350 Sport/ML350RWD
Euro lock pins
I just called my dealer and ordered the Euro spec lock pins (the shorter flush ones). $21 for set of 4 He said he could order some AMG pins (from C63) but I don't know if I want AMG stuff all over. I'll try these first. Parts shoud be here Sat or Mon. I'll post pics when I get them.
Old Jun 12, 2008 | 07:00 PM
alexyanglaw's Avatar
2008 C300 Sports, AMG 18 inch wheels, MM package, 6000K HID Kit, 20% 3M tinted all around
can you please post some pictures of the euro lock pins? I want to see the difference, and the price is good.
thanks for the information.
Best Regards.
Alex
Old Jun 12, 2008 | 08:01 PM
Lakerz4sho's Avatar
c300 sport
and also describe the install.. i know some people said that it wasn't that easy to swap out the rear pins.
Old Jun 12, 2008 | 10:07 PM
tanktube67's Avatar
2008 Black Out C350 Saks Edition / 87 VW GTI
whats the part number?
Old Jun 12, 2008 | 10:53 PM
AMGTestDriverNJ's Avatar
86 190E 2.3-16v, 92 500E, 03 CL55 AMG, 08 E3504M Brabus
Interested in both more info pt #'s please?
Old Jun 13, 2008 | 12:20 AM
joshieca's Avatar
'08 C350 Sport & '08 528i
I'm in! Post some more info...
Old Jun 13, 2008 | 12:23 AM
micropower99's Avatar
2008 Mercedes C300 4Matic
Can you get the part number's for the C63 pins and the euro spec pins? I really want the AMG pins
Old Jun 13, 2008 | 12:45 AM
Ok I found the euro Locking Knob part number for the front doors:
A 123 766 00 22
The North American locking knobs part number are: (front doors)
A 000 766 00 28
Are they suppose to be black or chrome? By the way the locking knobs (pins) have the same part numbers on the C63 as they do for the C300 and C350 (in the database)
Regards,
Daniel
Old Jun 13, 2008 | 01:47 AM
trial0r's Avatar
black c300 sport p1
are you installing yourself? i cant remember which (front or back) but one of them is a ***** to install.
Old Jun 13, 2008 | 07:17 AM
dalazernet's Avatar
2020 GLC300 4MATIC
Its back, and I'm looking forward to hearing how this goes... I think these door pins are the cheapest things I've ever seen on a Mercedes.... ugh.
Old Jun 13, 2008 | 10:16 AM
E350 Sport/ML350RWD
The part # I had was close but different (123 766 0022 9051). Not the typical part #. The rear pins are actually attached to the locking cable and are not supposed to be removed. That's why it takes the dealership 2 hrs to replace. When they come off they crack at the bottom. They are like a ball/socket attachment. Once you pull out the ball- the socket breaks. Fortunately one of mine broke so I could see. I will post pics as soon as I get them (Sat or Mon)
Old Jun 13, 2008 | 11:13 AM
Azn_C300's Avatar
Mercedes C300 Sport, BMW 745Li, VW Mk6 Golf TDI
Are there pictures of these pins? I hate the current pins and was thinking of getting the brabus ones.
Old Jun 13, 2008 | 11:49 AM
PHYBENZ's Avatar
1963 220Sb
They are the same type of pins. The only difference is that when the doors are locked they flush with the panel and when unlocked they are at the height of the US locked position. I have posted pictures of the difference before. In terms of design they are exactly the same.
Old Jun 13, 2008 | 11:54 AM
Devastator187's Avatar
2008 Sport C-300, 2003 Accord Coupe V6
All you do is just pull them off, and push down the new one...
Old Jun 13, 2008 | 01:41 PM
trial0r's Avatar
black c300 sport p1
there's a whole post about guys needing to take that whole panel off...
i'm confused.
Old Jun 13, 2008 | 01:55 PM
Azn_C300's Avatar
Here's a dumb question. People have said that the rear is ball-in-socket type and the only way for it to pop out is if the socket part cracked. Given that (picturing in my head), would not popping a new one in also crack the socket on the new pin? I really really want to replace that cheap *** looking pin, but want to do it right.
Old Jun 13, 2008 | 02:04 PM
imboom's Avatar
The rear are ball and socket ones which are very very flimsy. You can pull it off without ever noticing it. It's easy to replace those but also, its very easy to lose those again.
The front ones are not the same. Unless there is a trick involved in removing them, door interior panels are needed to remove.
Old Jun 13, 2008 | 02:24 PM
I only gave you guys the part number for the front pins because the back pins it is connected to the hose and technically there is no "part #" for the rear pins but for the hose and pins together.
AkaSigFreak, how come the part number you had was so long? There can be a maximum of only 10 numbers but yours has 14 lol. I'm going to check with the dealer this weekend to order the euro pins tho (not the amg as the amg uses the same euro pins).
Old Jun 13, 2008 | 04:22 PM
Ah I figured out why your part # was longer. The "9051" is the color code.
Old Jun 13, 2008 | 06:08 PM
E350 Sport/ML350RWD
My # did not have the "A" in front. That is the part # my source in England gave me. We I called the dealership they had no problem with it. I am going to try to replace my rear broken pin with the euro spec. If that doesn't work I will try to convince my dealer to replace with full euro rear part since they already have to warranty one.
Old Jun 14, 2008 | 06:42 PM
joshieca's Avatar
Pictures!!!!!!!!!!!
Old Jun 14, 2008 | 06:55 PM
jangy's Avatar
2015 S212
I like it all, except getting my arm pinched when the pin goes to lock. DAMN, that hurt!!
Old Jun 14, 2008 | 08:06 PM
Azn_C300's Avatar
Originally Posted by joshieca
Pictures!!!!!!!!!!!
I second that.
Old Jun 18, 2008 | 04:08 PM
E350 Sport/ML350RWD
Just picked up the parts. I am much happier now
I replaced the fronts but the rear are different (of course) so I guess I'll order the european rear pins now.
Attached Thumbnails Euro lock pins-new-lock-pin-unlock_01.jpg   Euro lock pins-new-lock-pins_01.jpg
Old Jun 18, 2008 | 04:30 PM
Azn_C300's Avatar
better..but still not up to what I consider mercedes quality.... unless the pictures don't do it justice, don't like the plastic.
