Speed Innovations ECU worth it?
http://www.brabus.com/index_en.html
I want to know how "programmable" are our ECUs???
can we do A/F tune with it?
1. open hood
2. take out ecu
3. send it to tuner
4. get it back from tuner
5. everything back to normal
is it really that easy?
i have seen them done it on my W211 before. they had to open the ECU, the the chip off, put it on their programming module to reprogramm, then weld it back on the ECU. Is that how it will be done on the W204? or is it something that they can reflush without taking the chip off the ECU, like how they do the BMWs. I know I have to send my ECU in since I live in Chicago now. But I was hoping they can put my ECU in a W204 and program it that way.
If you have any questions, just give SI a call and they can probably answer your questions better than I can. They seemed friendly enough and open to any inquiries.
It's not a "flush", but a chip replacement.
regarding the MB dealer. I took my car in for several services that they upgrade or flush on the ECU, but never they mention the detection of the ECU chipping or brought up any warranty issue.
But I did take my car back to Speed Inn. to get the ECU done again, just incase the dealer accidentally erase it.
headers and exhaust adds 20-25hp at most with the tune. plus the tune you'll probably see something like 30-35hp (40hp at crank if lucky) on the NA.
on the M272 SI tuned few member's w203 C350. those went up to around 290-300hp at crank.
what I'm hoping is that we can find out what is changed in the 2009 SLK350 to make 309hp at crank. a healthy 31hp more. i'm assuming it's only cam and adjusted fuel mapping.
Azn_300 - Did you get the increased MPG you were looking for with this tune?
Has anybody noticed better fuel consumption in any of their ECU tunes? I really want to go with something that lessons the burden of buying premium gas.
Be careful
2008 down maybe but for 2009 No...
I had my ECU sent to SI to program in April but the tune did not work on my car.
I had to replace my ECU because what ever they did to my ECU the car would not start when it did before there program and I'm still waiting on them to return my money....
