C350 Clear side marker installation (additional step)
Putting them back in is tricky, too. You just gotta play with it a bit.
without screws.. about 20 minutes.
With screws... about 35 minutes.
see my attached pictures on the above posting. once you put your hands in the bumper. you can feel around the housing. the screw is right next to the TAP, if there is one.
it's the 1st time that's tricky. Now i am probably do it in 4 minutes and 59 seconds if the lense doesn't have screws!!!!!
I have the c350 and i didnt have to use a screwdriver for my clears...
they also fit snugly jusyt like OEM... without screws...make sure you get the more expensive ones on ebay... the cheaper ones didnt fit right for me and i had to return them...
i picked my c350 up in october 2007, maybe the newer builds have screws....
