C350 with x-pipe sound clip
MBworld Guru
white and whiter
here you go as promised. you can see there's no rasp as compared to the C300 x-pipe videos.
standing rev
http://www.youtube.com/watch?v=I021FyD91NI
take-off 1
http://www.youtube.com/watch?v=v_IAB9OT8jo
take-off 2
http://www.youtube.com/watch?v=1I9iCV6uLy4
standing rev
take-off 1
take-off 2
CLK500 SPORT
hey frank you didn't remove your mufflers did you....i think the guy that did his removed his muffles as well he went straight pipes.........yours sound good as h...e double hockey sticks
MBworld Guru
white and whiter
nope didn't touch the muffler. just took off the resonator and replaced it with the x-pipe.
idle like stock, cruising like stock, only heavier throttle will reveal the new deeper sound.
Hi Frank
it sounds awesome. But did it effect the performance of the car?
Negatively?
Positively? how about the warranty issue?
Negatively?
Oh, also how much does it cost? is it hard to replace/install?
Super Moderator
What more could a guy want from his exhaust? Sounds great!
Pleased the X-pipe worked so well for you.
Did your co-pilot notice or object?
Oh yeah, you were wise to choose the 350.
MBworld Guru
white and whiter
warranty issue there should be none.
power wise, the car's new. I did notice at mid-high rpm it pulls a little better. no negative effect felt.
it was $150 total. The muffler shop had an right size x-pipe available. I took a look and it looked very well made and quality, so I went with it. couldn't be happier especially without the rasp I was expecting it would have.
it was $150 total. The muffler shop had an right side x-pipe available. I took a look and it looked very well made and quality, so I went with it. couldn't be happier especially without the rasp I was expecting it would have.
Also, did you take it for dyno testing? if not, do you plan on doing that? do you have pictures of the x pipe? you got it from Exhaust Depot, right?
Also, on normal driving, does it also make loud sound like that? I wouldn't want it to sound like that constantly. my dates may not like that.
MBworld Guru
white and whiter
$150 isn't bad. Is that for the part only or including installation? was it hard to install?
sound was described in post #5 in this thread.
sorry, should have read my carefully. What is the "right" size x pipe to put on our car? do you have pictures of it? was it made by the exhaust shop?
so, during normal driving, it's not as loud as take off... just wanna make sure. do you have the sound clip taken inside the car?
MBworld Guru
white and whiter
x-pipe's pre-made. didn't pay attention what size was the pipe. i think it was 60-65mm.
by any chance know who makes it? does the shop have another one?
cool. how much for just the part?
does it require cutting and rewelding? or you can use clamps?
thanks for the info.
Is it something i can easily find in a exhaust shop? or do you think i will probably have to order from your shop?
do you have the shop contact info?
