Preventing Headlight Washer. How?
Thanks.
Pierre
Thanks.
Pierre
It would be great if someone knows how! Plus if you wash your window when you're stopped, the headlight washers spray all over the car and make terrible marks! Whaaa
At least the headlights are clean! :-)
- Eric
The pump is the larger of the 2 pumps. (or 3 if it's a wagon)
if the headlights are off, then headlight washer doesn't spray.
now the problems is that Canadian W204 came with DRL.
this DRL is causing headlight washer to spray everytime when you spray windshield.
to fix the problem, convince dealer to gain access to DRL setting which can be fond on,
http://www4.mercedes-benz.com/e/cars...unktion12.html
In the W204 the pumps are not visible from the engine compartment.
That kit will bypass the every 10th wash and allow us to wash on demand by pushing a button.
I bet the cost of such a kit (relay, some wiring and a switch) won't be over $50 - and you can sell them for $200. I'd get one instantly.
TIA!
