I think I need HID's
Old Sep 25, 2008 | 01:19 PM
Vector02's Avatar
2008 C300 Sport P1/AMG
Originally Posted by ACdude
Can someone post pictures where they place the ballasts? I am really interested in putting them on my car.
I ordered a set from James yesterday. He said he'd try to post a DIY on the install, but that was only a few days ago. He mentioned mounting the balasts to the back of the headlight cover. I'll take pics of my install when the kit comes in.
Old Sep 25, 2008 | 01:27 PM
hutch300's Avatar
2022 GLE450
WHat color 6000K??
Old Sep 25, 2008 | 01:29 PM
Vector02's Avatar
Originally Posted by hutch300
WHat color 6000K??
I went 4300k for now. I'll be installing the Lamin-X headlight kit in the tint color, so I wanted the most light output I could get. If they're too yellow, I'll throw in some 6k bulbs.
Old Sep 25, 2008 | 01:36 PM
hutch300's Avatar
2022 GLE450
i want to see what you think of the color then i'll order mine
Old Sep 25, 2008 | 02:18 PM
Vector02's Avatar
I'll take some before/after pics asap. My goal was to have the HID's look as stock as possible. I don't know the color temp of the P2 package in the C's, but I think it's probably pretty close to 4300k.
Old Sep 25, 2008 | 03:35 PM
James@ACG's Avatar
07 RS4 sold, R53 Cooper S, 2008 Cayman S, 2012 GTR
As promised a short diy with pictures.
Old Sep 25, 2008 | 03:43 PM
  #32
James@ACG's Avatar
Here is the circle of life for the HID kit.
You start by removing the plastic cover on the back of the headlamp, and drilling a hole so that the wires from the HID bulb will fit through. The Rubber grommet is provided so that water does not enter the back of the headlamp.
So you'll drill a hole in the plastic cover, slide the wires through, and use the rubber grommet to cover the hole.
After this is completed, you'll install the HID bulb, and plug in the power and ground. It is Highly recommended to use a volt meter at this point so that you make sure that the power is moving in the correct direction. Plug the red or blue wire into the positive power, and the black wire to teh ground.
Close the cap, and then you'll be left with 3 plugs; a black little plug, a black/yellow little plug and a larger black/yellow hanging out of the back of the cover on the other side of the rubber grommet.
The large yellow and black plug will get plugged into the warning canceler, then the warning canceler will get plugged into the ballast. You will then plug the ballast into the final two little plugs that remain.
Old Sep 25, 2008 | 04:03 PM
  #33
James@ACG's Avatar
Here is a 6000k HID kit we did.
Old Sep 25, 2008 | 04:08 PM
  #34
James@ACG's Avatar
These HId's also work for your Fogs, I would suggest only a 35w for the fogs has the 55's would generate too much heat.
Old Sep 25, 2008 | 04:15 PM
  #35
mb_horseshoe's Avatar
2008 C300 Sport
Originally Posted by KA8
6000K will look more blue but less light output than 4300K. I've had both and I'd go with 4300K. It will look oem especially with the projectors from w204's.
when you say 4300k will look OEM do you mean Bi-Xenon-OEM or Halogen-OEM?
Sorry for the lame question
Old Sep 25, 2008 | 04:50 PM
  #36
Vector02's Avatar
I don't think stock halogen temperature comes anything close to 4300k.
Still need to find a place to mount the ballast. James, where do y'all mount them?
Old Sep 25, 2008 | 05:18 PM
  #37
phranksmbz's Avatar
09 c300 4matic
what resistors do you need for the fogs?
Old Sep 25, 2008 | 05:34 PM
  #38
KA8's Avatar
KA8
2002 E430
I meant oem HID lights both projector(like bmw's) and halogens(like IS300's).
Old Sep 25, 2008 | 10:54 PM
  #39
supernsx's Avatar
2011 C300 4matic, 2015 Porsche Macan S, 2006 R500 (sold)
Hi James,
Will the 55w too hot for even the low beam? I am afraid about the wires will melt if I put 55w instead of 35w in the C. Thanks.
Old Sep 25, 2008 | 11:11 PM
  #40
micropower99's Avatar
2008 Mercedes C300 4Matic
If I change my fogs to HID's, will I get any errors in the car? I might take my car to a good shop that is known for their HID installs.
Old Sep 26, 2008 | 11:59 AM
  #41
2008 C300 Sport
does anybody know the temperature of the OEM HID's?
Old Sep 26, 2008 | 12:39 PM
  #42
darstar's Avatar
E46 M3
Could we do a group buy to get a better price?
Old Sep 26, 2008 | 01:38 PM
  #43
hutch300's Avatar
2022 GLE450
There seems to be quite a bit of interest, i'd be in
Old Sep 26, 2008 | 10:38 PM
  #44
SAserg's Avatar
W212 E350
I would be in too!
Old Sep 30, 2008 | 05:48 PM
  #45
Vector02's Avatar
Ok, got my kit in today. Thanks James for getting it out to me quickly. Everything looks great, I just need to open the hood, grab my unibit and fluke, and find a place to hide/mount all this stuff.
Anybody complete the install yet?
Old Sep 30, 2008 | 05:54 PM
  #46
hutch300's Avatar
2022 GLE450
post pics as soon as you can PLEASSSSSSSSSSSSE!
Old Sep 30, 2008 | 06:49 PM
  #47
Vector02's Avatar
After planning/install is complete, I'll be sure to post some pics. I really want to make this mod as inconspicuous as I can. I don't want any extra scrutiny from MB technicians, etc. I would hate to have to deal with MB saying my warranty is void....
Old Sep 30, 2008 | 09:47 PM
  #48
Vector02's Avatar
Ok, I got them in this evening. The install was a bit tedious, but completed in about an hour. It was hard finding a place for the balast on the drivers side. I'm fairly happy, but I have a dark spot on the driver's side on the bottom left. I'll have to work with reseating the bulb and see if it makes a difference. Beam projection is adequate, color looks great, and visibility is much improved.
I'll write up picture descriptions later and make another DIY, but for now, y'all can just check out the pictures.
http://gallery.me.com/codykday#100327
Old Sep 30, 2008 | 11:47 PM
  #49
James@ACG's Avatar
Cory,
Great, to see you got them installed... never thought about cutting a notch on the cap, that is a great idea
As for a group buy, let me see what I can do, but honestly as you can see from the prices that stealth auto has, our prices are very very low. But I'll try to squeeze a few dollars out from somewhere.
Old Oct 1, 2008 | 01:46 AM
  #50
myinternetsucks's Avatar
Merc C300 sport, arctic white, P1, MM/Navi, iPod kit, 20% Tint, C63 Grill, X-Pipe, HID DDM Kit
What's caused that dark spot in the light beam?
