which brand of gas?
Chevron has worked the best for me. Shell has been the worst for me. Depending on actual location, your mileage may vary.
Strangely enough when we live in Hawaii and driving a BMW it was the other way around.
Paolo
Paolo
C300 Sport/Palladium Silver on Black/P2
I can only get 91, which sucks. I sure wish I could get 93 or 94 whatever you guys get.
I would always go to Chevron, but it's much more expensive for me (about 20 cents per gallon).
I use Shell 91 most of time. Sometimes I use 76's 91. Both are on the top tier gasoline lists alongside Chevron that was assembled by auto makers including BMW.
W212 2011 E-350 4Matic
Exxon 91 and Chevron 91, depending on whether I fill up near work, or near home.
Here's a link for those of you in Cali for 100 octane![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
http://www.osbornauto.com/racing/100locations.htm
Oh, and do a blend if you ever go to one of those spots.
1/3 of your tank in 100-octane (4-5 gallons), and top off with 91. Should give you about a 94-95 octane rating.
LOADED 08' C350 & 14' GLK-350 Diamond White (P1, MM, AMG Pkg, Ln Trkng, Htd Sts, Keylss Go)
2008 C350 | White | P2 | Pano
As long as it is 93 and above I dont care where it comes from, but I wont use Valero, The Racetrac stations around here have 110 at the pump $6.99 a gallon
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
1 Post
C-300, XC70, Wrangler
I usually use these brands. A couple of tanks ago I put in a lesser brand, same 92 octane, and immediately felt less power and experienced worse mpg. I'm now on the 2nd fillup post that and the mpg is coming back; maybe another tank?
Might be there was more water in that off-brand gas? I've used it in other cars without problem, but then I've never had the running mpg computer before ;-)
