Brembo Calipers Available For '09 C300 (w204)?
Old 10-23-2008, 06:14 PM
Alex@wheelexperts's Avatar
07 S550 & 08 335i
In order to go with a brembo caliper, you would need to replace the rotors also which would make it a full Brembo GT kit.
Feel free to PM me for special pricing on all Brembo products.
Old 10-24-2008, 04:56 AM
phranksmbz's Avatar
09 c300 4matic
what do you guys think?
brembo or rotora ?
Old 10-24-2008, 11:57 AM
Azn_C300's Avatar
Mercedes C300 Sport, BMW 745Li, VW Mk6 Golf TDI
brembo or rotora ?
Brembos............but I'm biased
Old 10-24-2008, 12:42 PM
VIPStyle's Avatar
2008 C300 Luxury
So how do you like your Brembo kit?
BTW, it looks awesome!
-Hiro
Old 10-24-2008, 04:02 PM
Azn_C300's Avatar
-Hiro
Loving every second of it. You going to Milpitas tonight? I'll be there around 9ish when the Sonic crew rolls in.
Old 10-24-2008, 05:53 PM
phranksmbz's Avatar
09 c300 4matic
Does anyone know if the brembo bbk will clear on our stock 17 inch c class wheels?
Old 10-24-2008, 06:13 PM
  #32
VIPStyle's Avatar
2008 C300 Luxury
Nice!
I probably won't able to make it tonight. Might go next week.
Old 10-24-2008, 06:23 PM
  #33
Flame3g's Avatar
CLK500 SPORT
don't know im wondering if they will clear my 18's as well
Old 10-26-2008, 08:01 PM
  #34
phranksmbz's Avatar
09 c300 4matic
i was just told that the brembos wont fit the 4matic, sucks again.
Old 10-31-2008, 04:19 AM
  #35
phranksmbz's Avatar
09 c300 4matic
So the brembos are not made for the 4matics. Thats a fact at this point but where can i find the answer to see if the AMG c63 brakes will fit the 4matics?
Old 10-31-2008, 08:41 PM
  #36
Chino's Avatar
Mercedes Benz C300 4matic MM
Originally Posted by PolePosition
+1 I painted mine red since it was the color I liked best with my Palladium silver C
+2 I wonder how that would look with my Capri Blue???
Old 11-02-2008, 08:24 AM
  #37
Boom vang's Avatar
2019 C300 Wagon; '75 Triumph TR6; previous: 2004 C230 6spd sold after 17 years of driving
Sorry to see Mercedes cheaping out on the calipers over the years.
In 2004 it was 4 piston AMG on the sport option
In 2005 they went to a 2 piston fixed
In 2008 they went to a 1 piston sliding with a stupid looking painted plate trying to fool those that are not in the know
It amazes me that as important the looks of the wheels, that manufactures pay little attention to the caliper looks unless you are spending $60,000+. This is especially important in today's wide open style wheels with thin spokes etc. It would ok if it was at least painted or powder coated (still does not give you the performance of a fixed caliper) but in my climate with the tons of salt on the road after 1 year you have this ugly rusty piece of iron peaking out through the wheels.
Mercedes is not the only culprit, BMW has these ugly sliding calipers on all their models except for the 135 with the M package where is it s 6 pot fixed those with the M3 don't even get it. Look at almost every Japanese car and you have these rusty hunks of iron.
I think we have to blame the bean counters trying to save every penny
Old 11-02-2008, 05:16 PM
  #38
MBworld Guru
FrankW's Avatar
white and whiter
however if you haven't noticed the stopping distance wasn't affected.
also BMW M has always used either 2 or sliding calipers on the M3 and M5 and they stopped nothing short of AMAZING.
Old 11-02-2008, 06:36 PM
  #39
Boom vang's Avatar
True, but track a car and the difference is noticeable. Biggest problem an M3 has when you do some track lapping, the brakes turn to mush. No race car would use a float because they would be done in a couple of hot laps.
Disadvantages:
-Not as heat-resistant as fixed calipers
-loss of braking feel
-heavier unsprung weight (bulky cast iron vs machined alloy)
Advantages
-cheaper
-simpler to maintain EXCEPT for those that live in areas where salt is used then more attention must be paid to ensure the sliding pins are clean and lubed and the sliding plates that the pad rests on is clean and free and not bound up by the rusting of the casting below that will squeeze the pad not allowing it to slide properly
-less parts
Old 11-02-2008, 10:52 PM
  #40
Distalero's Avatar
C 300
Huh? How are calipers unsprung weight?
Old 11-03-2008, 01:48 AM
  #41
jstaneff's Avatar
C-300, XC70, Wrangler
Same way wheels are. Kingpins, springs, shocks, A-arms, all contribute to the unsprung weight. If it has contact to the road before it contacts a spring, it's "unsprung".
Old 01-15-2009, 01:07 AM
  #42
phranksmbz's Avatar
09 c300 4matic
Anyone hear anything about some bbks for the 4matic yet?
Old 01-15-2009, 01:31 AM
  #43
RLE
RLE's Avatar
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
Weight
Don't get carried away, here. Shocks and a-arms are not unsprung weight since they are mounted to the body and I haven't seen a kingpin on a modern MB for a while.
Old 01-19-2009, 06:47 PM
  #44
jstaneff's Avatar
From Wikipedia (not best source, but a starting point ... )
Kingpin:
The kingpin is the main pivot in the steering mechanism of a car or other vehicle. Originally this was literally a steel pin on which the moveable, steerable wheel was mounted to the suspension ... No longer restricted to moving like a pin, the part was not necessarily still called a king pin; but in newer designs, the term may be used not for an actual pin but the axis around which the steered wheels pivot.
Unsprung weight:
Unsprung weight includes the mass of components such as the wheel axles, wheel bearings, tires, and a portion of the weight of driveshafts, springs, shock absorbers, and suspension links. If the vehicle's brakes are mounted outboard (i.e., within the wheel), their weight is also part of the unsprung weight.
So, There's a LOT of unsprung weight on our cars ...
The photo (not a w204, but a modern Mercedes) shows the Kingpin as the area between the upper and lower arm that forms the axis on which the wheel rotates.
fyi
Attached Thumbnails Brembo Calipers Available For '09 C300 (w204)?-frontsuspension.jpg
Old 01-20-2009, 04:02 AM
  #45
Uga Uga's Avatar
2019C63S coupe
Does anyone know what the difference is between these two calipers posted by Azn300 and Poleposition
https://mbworld.org/forums/attachmen...4-dsc07477.jpg
Please open the above link for a larger picture of the red caliper, Thanks.
Old 01-20-2009, 02:55 PM
  #46
micropower99's Avatar
2008 Mercedes C300 4Matic
^ There is no difference, those are stock calipers just painted a different color.
Old 01-20-2009, 10:46 PM
  #47
smikes19's Avatar
2009 C350 P2 MM Pano
There's clearly a difference in the way that the calipers look. My guess is that one is a picture from a C300 and the other from a C350. The C350 has larger brakes.
Old 01-21-2009, 12:33 AM
  #48
raver's Avatar
Merc A45 AMG ; Porsche 911 C4S
Believe you may be right...my C350 has calipers that look like the one in red.
Old 01-21-2009, 01:19 AM
  #49
I meant to say their OEM
Old 01-21-2009, 01:41 AM
  #50
raver's Avatar
On a separate note, does anyone know if the 6/4pot combi of the Brembo BBK will fit behind the 18" AMG 5-spoke rims? or would i need to go +1 on my rims ?
Thanks!
Quick Reply: Brembo Calipers Available For '09 C300 (w204)?
