DIY: Rear-View Camera under $200
I removed the command to find a rattling noise and it's a piece of cake on late models, takes 5 minutes to remove vent trim + 2 screws. Another 10 minutes to remove the glovebox greatly helps to wire under the carpet as once glovebox is removed you can remove passenger plastics covers/carpet, you can remove door sill by just pulling it, really easy.
Pascal
1. Go buy the ebay cam....worth it.
2. Make sure to remove the old weather strip gasket of the old license plate bulb cover and reuse it to have a proper seal and secure fit
3. Make sure that the cables for the cam is not on the bulb's way. If it is, remove the screws of the housing and re-route the wires as shown.
4. I find it easiest to wire the power to the #71 fuse (just tap) and just unbolt the ground nut and tie the camera ground wire and re tighten it again (no soldering, no cutting, no use of add a fuse)
5. It will be easier to install back the trim piece while the camera is not yet secured as you will have a hard time placing the chrome trim back.
The ebay cam that I bought is even clearer than my GLKs oem cam so don't be afraid to buy them. This is how it shows during night time....not bad. You don`t really lose all of the light of the bulb.
BTW - been meaning to ask, are those guide line built into the camera or what MB system displays?
As I see it the FAKRA input is fully occupied with the iPod adaptor cable. Is it possible to simply splice into that cable with another set of FAKRA plugs and sockets, or can the video simply be spliced into the wires in the iPod cable (and if so, which ones)?
Any ideas??? I have an OEM camera (lucked out in a junk yard).
https://docs.google.com/spreadsheet/...VE&usp=sharing
One of the things I am still considering is how to run the RCA cable from the trunk to the dash. Considering running the cable from the bottom trims and then from under the passenger side carpet by the cabin air filter to the back of the radio instead of through the glove box. Anyone have any suggestions or advice on that?
Looking forward to having a reverse camera...
Just received the camera from honk kong, look a bit cheap, i'll glue the two pieces more firmly as its really easy to pull off the cam from the translucent support.
Going to install it i a few days, i had to remove the glovebox to find a rattle noise caused by the little a/c tube and it's really easy , warning while removing the undercover, the man on the video is not doing the right thing, you see the little hook at approx 1:35 and spotted with an arrow 2:35min on the video ?
There is a hole under to put a finger then push the hook to the right to unlock it instead of pulling everything like in the video.
I unfortunately damaged the hook by doing like the man in the video and see after the hole for releasing it, too late for me not a big deal it's invisible but don't do the same error
Pascal
Actually the camera i bought doesn't look exactly like the pictures on ebay so I don't know if its going to be the same resolution and TVLINES as in the description but there is no way for me to know until i install it. Kinda annoying and the risk i took when buying from China but its a pain to send it back and get a new one since this one took over a month to get to me...i'll just live with it if there is a problem. Maybe next time i'll buy a better one from some where local.
- Ken
Pascal
Use a 12V supply, such as a jumper battery, to power up the camera, and find an old TV with a RCA input, to see what the image is like before installing in the car.
anyway i finished the installation even if the cam was broken and it works more or less with the broken lens, but to be honest i'm not happy with the plate light, as my car has original leds as you see in the picture below, the whole light is one piece with a special connector, i cant just remove the led and use it in the camera lamp housing, it's impossible, so i had to tap the led lamp over it but it's crap, lighthing is too dimmed for my taste.
So, i just bought another camera, but this time a simple one with a screw, i hope to install it in the pre-cut place around the light and leave the original led lights in place:
http://www.ebay.fr/itm/CCD-SONY-Rear...item1c3902bce0
Very easy to wire from the rear trunk to the command, everything invisible, the hardest part was wiring from trunk to the rear seat through the little left hole filled with grey foam (i used a hard metal wire to pull the rca cable).
Pascal
