Interesting Fact about 6th Gear in Automatic c350 transmission
After getting my 2008 c350 back, I played with the gears a bit to see if I could receive similar results...
Here is what I noticed:
Cruising the highway at 70 mph in "D" or standard automatic mode, the RPMs are right about 1900-2000.
Cruising the highway a 70 mph in "D6" or the top gear of the semi-automatic mode, the RPMs are right about 2200-2300.
In "D6", I noticed the car was quicker to accelerate to 75 when I hit the gass than in "D".
This doesn't make sense though really, because in both cases, the car is in 6th gear, right?
I think that maybe when in "D6" semi automatic mode, the car's ECU is more responsive and quicker to give gas???
What do you guys think? Anybody else notice the difference in RPM's between the two 6th gear methods????
so when your in D, your really on 7th while cruising on the freeway. thats why when you move the shifter to the right to do the manual mode, it goes to 6th...
Please DELETE this thread MOD
D6 is the highest it goes numerically
I have never seen D7
when in top gear and I move it one down it will show D6, move it up it will show D.....
just a side note - if your in some of the lower gears, 2-3-4 and so on and you move the shift lever to the right and hold it, it will go to the top most gear "D" automatically...which will put you back in auto shift mode once again....
Manually shift up, and you will see D5, D6, then just D (7th) as there is no higher gear after that, so plain old D is the highest gear, and semi-auto becomes same as full automatic mode.
You thought you were in charge, didn't you?
as i shifting from 1st to 2nd, to 3rd, to 4th, to 5th, to 6th and then finally to 7th. the other scenario is if 6th goes to D. that is all.
The numbers represent the highest allowed gear for the transmission. So, if you select 4, it will change from 1st all the way up to 4th as you accelerate and then hold 4th for as long as possible. Once you hit redline, the car will force an upshift.
Holding the shift lever to the left for 2 seconds will select the lowest possible gear for that given speed. Holding the shift lever to the right for 2 seconds will put you in D.
You cannot select 7, it is D.
However, in the USA, we don't have full manual capability, so that is why we never see 7. We get a dumbed down car here.
It also means, when you have beed upshifting in manual mode, that you have gone from 6th gear (D6) to 7th gear (D) with that last shift, and ( if you don't bump the shift knob again) you have returned to automatic mode.
