Tire Pressure Monitors
Old Nov 19, 2008 | 04:50 PM
Chaz00Blue's Avatar
2008 C-350 Palladium Silver and MM.
Now that we have had a big cold snap in NC, I am having trouble with my tire pressure monitors. At night my car sits in a warm garage, but when I'm at work it sits out all day. When I leave work I get a red screen warning me to check the tire pressures. I assume that it is caused by the fact that the air in the tires has contracted and is causing the warning. Anyone else experiencing this problem?
It's possible that I just have one monitor that is having problems. What do you think?
Old Nov 21, 2008 | 12:30 PM
Chaz00Blue's Avatar
Nobody is having this problem????
Old Nov 21, 2008 | 12:40 PM
Television's Avatar
CL500 216
I gave up on the pressure monitors in the wheel valves,, many cars can have the other tyre pressure monitor that works of the speed sensors in the wheels,, I know many 2003 203 cars where this has been activated on STAR so why not on your 204
Old Nov 21, 2008 | 01:08 PM
VD$'s Avatar
VD$
E350W4
My car displays "Correct tire pressure" warning message every time temperature outside drops. Continental low profiles tires seems to be very sensitive to temperature changes. Got this message on the screen today, went to the gas station to check - rear was -5psi, front -4psi. Checked it about one month ago. Tires on this model are far from perfect - I've changed 2 tires and fixed 4 in just one year!. On W203 I replaced only one (and it was my fault).
Old Nov 21, 2008 | 02:03 PM
peet's Avatar
09 C63
If this bugs you - just go into the onscreen settings and reset your new "monitored" point of the pressure. It's not like the temps will change drastically again in a day! However, technically your tire pressure IS down right now, and when it warms up by driving it gets to the lower threshold - so add a few pounds for good measure so you're not destroying the sidewalls.
Cheers.
Old Nov 21, 2008 | 03:00 PM
who8888's Avatar
15 E350 4Matic
I have the same thing happened to me back couple of months ago during summer and I thought it was too hot. I reset it couple of times but it keep coming back and then I get the RED warning. I put it off for a little while longer until I found my old cheap tire pressure gauge and measured all four tires and found one of them to be really low on pressure like at 25. Drove to the gas station and use their gauge and same 25 psi showed up. Added air and the warning is no longer there. I am at VA so I get the same temp swing like you.
Go check all your tires. One of them must be really low to get the RED warning.
Old Nov 21, 2008 | 04:39 PM
Chaz00Blue's Avatar
The first time that I got the red screen, I jumped into the gas station and they were only down 1 PSI, each. I checked them again with my didgital when I got home and again they were only down 1 PSI. Maybe I have a bad pressure monitor in one of the tires.
Old Nov 21, 2008 | 05:21 PM
VD$'s Avatar
VD$
E350W4
I think we are in between of two fires - user manual always recommends to check tire pressure once a week and not that many people follow this rule religiously. But it was never be such an issue since W203 did not use low profile tires, that are more sensitive to temperature changes.
So we cannot blame technology too much since this is only a "messenger" and two problems are described above (unless sensor is really damaged)...
Old Nov 21, 2008 | 07:24 PM
who8888's Avatar
15 E350 4Matic
Well, after I posted my msg, I was heading home and guess what. I got the RED tire pressure notice. Now I know what you are saying b/c it went away by itself. Hmm.. That would stink if cold weather does cause the TPMS to go nuts
Old Nov 21, 2008 | 08:08 PM
VD$'s Avatar
VD$
E350W4
I saw real RED message when killed my tires twice. And it means that you have to switch to spare. It is very different than correct tire pressure and there is no chance to miss it!. What never happens to me - having RED message as “false positive”. Temperature changes (when pressure was within reasonable limits prior) generates warning only. If the message is RED, then there is a high chance of seeing a nail in the tire (tire punch may be small and computer will display only “correct tire pressure” for some time...)
Old Nov 21, 2008 | 09:24 PM
nukefixer's Avatar
2012 US Edition C300 Luxury 4-Matic
Nitrogen instead of air
Greetings,
Drove off the Mercedes dealer lot and went down the street to a tire dealer and had them replace the air in the tires with Nitrogen, google it and read up on it, I have yet to get an error tire message since then!
I learned this from my last car a VW Jetta TDI, the VW dealership recommends replacing air with Nitrogen, I even put it in my wifes Toyota Yaris........... nitrogen is the way to go!
Nukefixer
Old Nov 21, 2008 | 11:11 PM
orie's Avatar
2008 C350 Sport
mine has been going nuts the past week.
my car sits in the garage at night and then outside all day. I haven't seen the message pop up in the morning driving to work but 3 times this week its popped up red on the way home. I've checked the tire pressure all three times and haven't noticed any difference in pressure.
very puzzling
Old Nov 22, 2008 | 01:08 AM
jstaneff's Avatar
C-300, XC70, Wrangler
Thinking out loud here .....
Is it possible that there's condensate getting into the sensor and freezing? That might account for the bad readings, especially if the ice that forms interferes with the sensor's mechanism.
Of course, MB should have tested this in all their Swedish testing? Maybe, maybe not. We tend to have somewhat interesting temperature swings in the US, and that might be an untested scenario.
Dunno.
Old Nov 22, 2008 | 08:02 AM
Ron Jr's Avatar
2013 C300 Sport Black Darth V3.0
Got low pressure warning this AM and since I had to get gas anyway I checked the pressure (all were low -5 or so) and topped off. This should be done when the tires are cold anyway and the gas station is only about 100 yards from my driveway.
Old Nov 24, 2008 | 08:58 AM
tpick23's Avatar
E63
Cool Great Thread!!
I read this thread last week and I am glad that I did. We moved this weekend to another house in the same neighborhood and the garage is still a mess so the cars sat outside last night. Here in NC the temp got down to the high 20s. As I got in the car I thought about reading this thread and was wandering if I would experience the TPMS issue. I have the 18" AMG style IV.
So....On start up and exiting the driveway, no red indicator. About 5 miles later it did light up. I decided to keep driving and it stayed red for 15 miles or so then went off. I did not stop the car or turn off the ignition or reset anything. It just went off.
It looks like the sensors are extremely sensitive and I think the nitrogen fills might be a good idea for these cars.
Old Nov 24, 2008 | 11:28 AM
norb's Avatar
2009 C63 AMG
I don't think anything is wrong with the TPMS. Tire pressure does decrease when its cold, so it will set off the warning. Then when you drive, the friction causes the tires and the air in them to heat up and increase pressure.
Old Nov 24, 2008 | 12:48 PM
VD$'s Avatar
VD$
E350W4
I think you right - we all trying to blame the mirror. Just have to start checking tire pressure once a week as manual prescribes. The only work around can be using Nitrogen instead of air. I read a lot about this for aircrafts and event there are few folks who uses it in a car, but do not see everyone switching to it. Probably total cost of this solution is too high to consider...
Old Nov 24, 2008 | 01:13 PM
Star & Laurel's Avatar
C 350 Obsidian Black
Check your tire pressures and set to the correct pressure in the morning. When temperatures are the lowest. After setting to the pressures listed on the door / gas fill door reset sensors via dashboard. Once you do this you will not have a problem unless you have a slow leak, or a faulty sensor.
Notice how you guys are receiving the "correct tire pressure" warning now that it is getting colder? That is the only reason. Yes the sensor are sensitive, but they are just trying to prevent premature / uneven wear, or worse yet any accident. Also keep note that underinflated tires are more likely to bend / damage a wheel in the event of a rough pavement.
Nitrogen is used in aircraft because of the extremely cold temperatures they are exposed to and then immediately need to be used for landing. It is becoming more common in automotive, but is not a necessity.
Old Nov 24, 2008 | 07:59 PM
RLE's Avatar
RLE
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
Pressure
Dunno.
Not possible. The sensors are completely sealed in an epoxy-like material. Except for the valve stem and nothing's getting in there.
I am quite surprised at the panic level about this.
Old Nov 26, 2008 | 02:44 PM
jrct9454's Avatar
'14 GLK250 Diesel
Yeah, me too....
Get a gauge; set the pressures when cold; reset the system.
Pressures will drop about 1 psi for every 8-10 degree drop in F ambient temps. No biggee.
Old Nov 26, 2008 | 02:48 PM
Chaz00Blue's Avatar
That will work, provided that the sensors do not detect an over pressure. Does anyone know how these sensors work? Do they only send a warning when the pressures are lower then the set point or do they also warn you when the pressures are high?
Old Nov 26, 2008 | 06:36 PM
jrct9454's Avatar
'14 GLK250 Diesel
A good question - never heard of anyone getting alerts with overinflation, but that doesn't mean it can't happen.
Once you've reset the "baseline", there's a tolerance level - but I don't know what it is. Something sticks in the back of my mind along the lines of 10-15% from the baseline, but I wouldn't swear to that in court.
Ours have been as high as 35 psi cold and as low as 30 psi cold without a reset and without generating any warnings. Since I never let them get outside this range, my experience is limited.
Old Nov 26, 2008 | 08:34 PM
hmc's Avatar
hmc
2009 C300 Sport 6MT
I just had this issue addressed.
There are 2 "minimum pressure" settings in TMPS. There are by default set to what MB recommends on door panel. In my case, its 28/33, which are too high for "minimum values"
You will get warning if you try to reset a new threshold and your actual tire pressure is below these min values.
I had them changed to 25 all around and this addressed issue. Keep in mind that these are just "minimum" values. I can always reset my new threshold value anywhere above 25 w/o getting warnings. I currently set to 30/32
Old Nov 27, 2008 | 03:30 AM
Diesel Benz's Avatar
Looks like MB has been a bit too strict with the warning limits on the W204 since so many drivers get the message at cold weather. This option to tune the minimum level is a good point to remind about.
The TPMS warnings are not exactly simple. First, if you over-inflate tyres, the system would apply automatic fill detection and would autonomously set these new values for a reference (different from the older Beru system).
A soft warning is give if the pressure drops by 0.25 bar for a period of 12 minutes. If tyre pressures raise to the minimum of 0.1 bar below the set limit during this 12 minutes, no warning is given.
A pressure loss of 0.5 bar or 20% gives a hard warning. A warning is given immediately at 0.7 bar pressure loss. Above 0.7 bar the warning is delayed by 5 minutes and suppressed if tyre pressures raise to at least 0.2 bar below the reference during this time period.
If however a leak of 0.2 bar or more per minute is detected, a warning is given already before the warning thresholds are reached.
Old Dec 3, 2008 | 07:09 AM
C300SportFahrer's Avatar
C300 Sport
Hello All,
I'm getting ready to change over to snow tires (I should of already but the wheels were on the way) The dealship here has told me that the TPMS needs to be reset via star diagnostics. I have done some searching but have yet to find anyone that had to have it hooked into the computer to reset this.
if it makes a difference i'm moving from the 18" AMGs with summers to 17" stock C300 wheels (thanks TX21!!!) with Mercedes branded sensors.
anyone else have to do this? I just don't want to have it done for no reason as well as the charge that comes with it.
thanks
Shawn
