How to launch a w204 from a standstill?
Old Dec 12, 2008 | 03:37 AM
german-anger's Avatar
C350 Sport 4M
Just wondering if you guy guys had any tips on how to launch an automatic w204 car as hard as possible from a standstill?
Old Dec 12, 2008 | 03:49 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
traction control off, power brakes to 2000rpm, off the brakes and on the throttle.
OR
you could just step on the throttle.
Old Dec 12, 2008 | 03:50 AM
micropower99's Avatar
2008 Mercedes C300 4Matic
For the 4Matics, I would just put it in S mode and slam on the gas. I love the acceleration from a stand still to max. For the rear wheel drive I would just assume to do a power break to a certain number of rpm's and then let it go with minimal wheel spin?
Old Dec 12, 2008 | 04:26 AM
C350 Sport 4M
I went from a RWD (last car) to a 4Matic. I'm used to brake torquing then letting the wheels spin a bit, but its kinda weird on a 4matic, it doesnt work like that at all, I guess thats 4 wheels dedicated power for you... =p Fastest so far is just flooring it from no brake and dyno mode engaged, feels like it shaves off a second or less than S mode.
=\ I was trying to build the revs to 2k once and then I realized I was AWD and that totally tripped me out, and the car like didn't move at all, hill assist maybe came on? oO.
Old Dec 12, 2008 | 01:23 PM
Sanjuro Makabe's Avatar
C300 4matic
I think with our 4matic rides, just turn off ESP and floor it
Old Dec 12, 2008 | 01:52 PM
mac911's Avatar
C300 Sport/Palladium Silver on Black/P2
I've read on other forums people say to hold the gear shift to the left for a few seconds, it puts it in the optimum acceleration mode. Then it will not shift until red line in each gear, but I'm too scared to try it. ha-ha.
I don't want to hurt the car.
Old Dec 12, 2008 | 02:06 PM
C300 4matic
yes holding the gear shifter to the LEFT (-) will put the transmission in its most "optimal" gear. But I think it only works when your car is in motion, and don't worry about breaking it...its designed so you can't really screw it up but expect your car to choke/slow down tho
and keep in mind these type of "tiptronic" transmissions are slightly different.
Correct me if I"m wrong, putting your gear at 4th when you are at a stand still doesn't mean your car will start at 4th, it'll still start on 1st/2nd depending on C/S. All this means is your transmission will go until it hits the 4th gear and it'll stop there...think of the transmission as a "gear limit" rather than an actual gear...at least this is what I observed...
i'm no expert, someone else care to explain/correct me? thanks
Old Dec 13, 2008 | 05:13 AM
akbro93704's Avatar
2014 C250 sport
Thats if you're already moving....say youre going 45, hold the lever left for a second, and it will downshift into the "optimal" gear for max acceleration. It won't hurt your car. The transmission will always upshift at redline, and it won't let you downshift into a gear that will over-rev the engine if you're already moving. Completely safe.
On dry roads my C300 won't break traction if I floor it in a straight line, so ESP on or off truly doesn't matter. Haven't really tried brake torquing yet. I think just mashing the throttle from 0 is the best way to go
Old Dec 14, 2008 | 12:14 AM
RLE's Avatar
RLE
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
You are exactly correct. I'm surprised how this confuses some people.
Old Dec 14, 2008 | 12:47 AM
C350 Sport 4M
hahaha, okay awesome. best way = floor it, wow end of discussion
