10mm spacers and lug bolts
X3 and 2012 C coming soon
I have these for sale. Especially good if you have aftermarket wheels that do not have a low enough offset to look staggered. Thanks
Click
https://mbworld.org/forums/wheels-ti...ml#post3241884
Click
Sorry, I didn't even pull out of the garage. I've seen photos of member's cars that appear to have wheels that stick out more than mine did with the spacers. I think if you hit a bump that would compress the suspension enough, they may rub a little bit. I am lowering with H&R coilovers, so I did not want to risk it. The wheel clears fine, it's the Conti tire that had me worried.
Check out White_glass_top's photo album. His wheels stick out quite-a-bit. You might ask him if he gets any rubbing. I think you'd have to hit pretty hard to compress the spring enough for the inner fender to rub the tires.
I'll post pics of everything when i get them on... tinted windshiled... black grill with satin clear... clear side markers... debaged...tint ... you will all see soon
08-C350 black/black
hey hutch, did u ever get the spacers on? not planning on lowering so im thinking about going that route..can you post pic's so i can see wut it would look like? do they rub?
08-C350 black/black
Hey Derspeed, did you go with 5mm spacers or just keep things stock?
I installed 5mm. I'll take some pics when it's lowered because you can't really see a difference at stock height. Looks like I may have to do front spacers too.
StickyZ, the lugs are 14 x 1.5 dia. The length is determined by the thickness of the spacers. If you order from ecstuning.com, they will know what you need. When I bought my stuff from them, I watched the rep add the info in their database.
You'll need this info:
http://hrsprings.com/scripts/appguid...ENZ%20|%20C300
For those with 10/12mm spacers
