Fog Lights and Eyelid Lights
I have not clue about the lights and figured maybe some people could help me out. I want to change my fogs and eyelid lights...How do I choose the right ones? like I don't wanna have the light error message or anything...
and how do I change the eyelid ones and pick the right bulbs too?
Any input would be great thanks!
Fogs are H7 for AVANTGARDE and H11 for ELEGANCE line. Fogs need to be a yellow tint though, yellow light reflects less in fog than white light.
Regards
I see quite a few threads about error free stuff. Just need some recommendations and suggestions from the gurus here.
1. The eyelid LED with built in resistor from Japan, what is the color temperature?
2. What is recommended for eyelids and fogs that produces 4300K/5000K/6000K temperature range that does not throw a code?
Many thanks.
Many thanks.
2. PolarG M4 as eyelids, or the German LEDs I was selling or the LEDs from PIAA that I am selling. 4500K is OEM color. Xenon filled blue halogens will not throw an error code (same amount of watts) or you could install a HID kit of 55W which also shouldn't give errors.
1. The ones by a member in ,Nagoya Japan using his wife's car (C350 in red). Costs somthing like $300 dollars for it and only available thru MB dealer as an option. There was mention of some part nos.
2. Can you please recommend LED for eyelids and foglights with temperature of 6000K? Oh once again, built in resistors for an error free thingy.
The only 6000K LED W5W I can think of are PIAA TERA, but they are not plug and play. More like cut,plug,plug some more and then play
But install is straightforward and not hard.6000K fogs? Only solution is to get an aftermarket 55W HID kit. Some drilling will be required. And make sure fog HID and low beam HID use the same brand of bulbs or you will see a color difference, even in same K value!
I'm still deciding what to do with my fogs. I'd like something that is closer in color to the headlights.
and a damn shame that the Halogens (I fitted 100W bulbs
) are activated too for large lights. Even with the DRL on they come on too and make everything yellow
Should've gotten the auto lighting thingie, but the MB options list was not really clear on what it was and it was very expensive so
My fogs are blue Xenon look bulbs. You don't see it when they come on (automatic turn assistance or smth) but I don't care at least they're not yellow anymore
Many thanks.
To make matters worse, I took my car into the dealer because apparently my anntena is broken, after 3 months of owning the car, so my GPS doesn't know where it is. The last time I was there, one of the service guys said they'd replace my bulbs for me. So I brought it in today, they called me and said: "Are you sure you want to replace these bulbs, the stock ones are better." And I told him the ones I bought are much whiter. Then he said it will be about $140 to get them put in because they need to take the headlights off. How ridiculous is that?? I mean I can get to the passenger side bulbs, just too scared to pull really hard on the wires to get it out, but no way you take of the entire headlight...can't stand these guys.
And they are relatively easy to install thanks to wire clamps in the box.
... they would look awesome on the car though
