C300 flat tire and cost to fix?
Old Jan 28, 2009 | 07:50 PM
R0CK632's Avatar
2008 Mercedes C300 Sport
I have an 08 c300 sport and got my first flat tire.. Anyone know the price of a new tire from the dealer? I'm going to the dealer tommorow and I'm hoping they can fix it. Don't see any nails and threw a can of fix a flat in there just hope it hold up till tommorow... Thanks
Old Jan 28, 2009 | 08:15 PM
Azn_C300's Avatar
Mercedes C300 Sport, BMW 745Li, VW Mk6 Golf TDI
If it's just a flat tire...you can take it to any tire shop to get it repaired. Something to keep in mind if mercedes inflates the repair cost of something as easy as this.
Old Jan 29, 2009 | 01:33 AM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
It sounds as if you did not put the spare on. Why?. I had my tyre punctured by a small sharp piece of basalt . It cost me A$20 to have a plug inserted at a independent tyre retailer.Just be sure to go to a reputable business because if the damage to the tyre is too great it should be replaced , not repaired.In my experience ,a small hole in the tread section is usually repairable but damage to the sidewall is not .
Old Jan 29, 2009 | 02:13 AM
mac911's Avatar
C300 Sport/Palladium Silver on Black/P2
I also say try a local repair shop.
When I had one go down last year, I knew it was beyond repaid because there was a several inches long by 1-2 inch wide piece of wood in the tire.
So I ordered an identical tire on tirerack, took the bad tire and wheel to tire shop, and they switched them out and balanced it for me for $25 or something.
Old Jan 29, 2009 | 07:39 AM
RickP330's Avatar
2019 GLA 250 - I am in purgatory right now...
Take it to the dealer, it's not that bad. Me/Be won't plug a tire you can drive over 100 mph on. They will patch it from the inside and rebalance the tire. I think the repair was <$25 I had it done. I also had a tire replaced. it was>200 for a conti pro.
RickP
Old Jan 29, 2009 | 07:59 AM
Ron Jr's Avatar
2013 C300 Sport Black Darth V3.0
I agree with Rick no plugs either patched from inside or a new tire. But I would use an indie tire shop by me.
Old Jan 29, 2009 | 10:56 AM
MBTex's Avatar
2008 C350
I'm not completely sure on this (meaning I'm not in the tire business), but using the fix-a-flat often makes it more difficult to make certain repairs to the tire, so you may be limited. I was always told that the fix a flat was a last resort (only use if your spare is also flat or multiple tires go down) for this reason.
In the future you might want to consider purchasing a warranty from one of the national tire chains. In my experience they are very good about tire repairs and I've even had tires replaced under warranty that were "questionable". Of course that warranty will cost you much more than just a one-time plug or patch job.
Old Jan 29, 2009 | 11:11 AM
hutch300's Avatar
2022 GLE450
fix a flat just is a pain... they have to clean the tire extra before the patch... and as mentioned above patch from the inside or replace.... i think plugs are outdated and not so say... more like a trail fix for a truck tire or backwoods shop at this point.
Old Jan 29, 2009 | 06:37 PM
Carsy's Avatar
[QUOTE= i think plugs are outdated and not so say... more like a trail fix for a truck tire or backwoods shop at this point.[/QUOTE]
I am interested to know how you would suggest repairing a tyre ?
Old Feb 2, 2009 | 12:44 AM
german-anger's Avatar
C350 Sport 4M
it depends where on the tire the puncture is. It should be cheap if it has punctured straight into the tire and it can be repair with a simple plug. However there are also weak spots of the tire which = very hard to repair =p so depends where you struck gold.
C350 Sport 4M
plugs are like $20 or less.
