sprint booster
It's total BS. Its an operational amplifier that amplifies the output signal from the throttle pedal. Basically, all it does is increase the sensitivity of the throttle pedal by some constant, like 30% or so. So it makes the car feel faster b/c you are used to pressing the pedal and getting a certain response, but now it's just like you are pushing it further. It doesn't decrease the "lag" time between your input and the engine's response.
https://mbworld.org/forums/c-class-w...ic-review.html
There are many threads about a Sprintbooster but by my car it was a good solution to get rid off the lag i had. The gas-pedal is much more responsive/sensitive than without the SB. And the lag wasnt gone without the SB and a full throttle reset!!
So here is a satisfied customer off a SB, it dont give HP ,it dont give Torque but the gas pedal reacts much much better!!
read this:
https://mbworld.org/forums/c-class-w...ster-w204.html
I was skeptical at first but I figured I'd try it for $300. I was very impressed. My friend drove my car before and after and then ordered one for his 08 ML350. He is very happy too.
