tire tread depth in snow
I want to take my C350 to the snow, but my tead is down to where the tread is even with the wear bar on the rear tires, is it ok for me to go up there? There should be minimal snow... maybe slushy...
C 280 4Matic
Coming from country with lots of snow, I was wondering, why cant you just put winter tires on factory wheels and switch them when needed? We are even forced to do it during winter by law and driving is way better, I understand, that it is different in California, but I cant even imagine to drive on summer tires in snow.
2014 Ghibli S Q4 & 2008 C350
I would suggest certainly putting your stock wheels and tires back on. If they are the Michelin all-season tires you should be just fine in light snow/slush unless it's really hilly. I put Blizzak tires on in the winter, but I'm usually slow to get them on come winter so I do drive a bit on the OE Michelin tires and don't have too much trouble getting going or turning, but the Blizzak's are night and day difference.
So the problem in Southern Ca is that you have to drive at least 1 hr to get to the snow. Sometimes even 3-4 hours to see the snow. Is it OK to drive on the freeway with snow tires on if there is no snow on the ground? Reason is because when you hit the mountains, there will be snow, but I cant bring an extra set of wheels to change when i get up there...
the problem living in So. Cal. is: snowboarding in the morning & going to the beach in the evening... .what tires do you put on!!!???
Re: snow tires, I can only speak generally, but typically if you drive with them with temperatures above 45-50, they start to wear fast due to the soft/sticky compounds used in the tires. If you do drive in moderate temps like that, just drive easy and try not put too much stress on the tires which will cause them to wear faster, ie. hard excelleration and cornering.
2007 E63
Must be rough! ![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
2007 E63
Change your driving style too, once you hit colder temperatures and snow. Slow down and take it easy.
