View Poll Results: who has wheel locks
YES
36.71%
NO
29.11%
DON'T CARE
11.39%
I DEFINITELY WILL GET ME A SET
22.78%
Voters: 79. You may not vote on this poll
Wheel Locks
Old 03-07-2009, 07:55 PM
Rick Hunter's Avatar
'08 W204.081; M 272.948 KE30; Colour Code#792
Originally Posted by cbcharlie
is that amazon link the right size for our cars? i'm assuming it comes with the key as well?
Originally Posted by mb_horseshoe
Rick Hunter, can you confirm that this link is the right fit for the w204?
Of course it is. I ordered my set as well as left feedback!
Old 03-08-2009, 11:13 AM
Ron Jr's Avatar
2013 C300 Sport Black Darth V3.0
I can confirm Ricks find. I picked a set up at a local parts store (paid 10.00 more) and the fit fine. Much nicer than the ones I had many years ago.
Old 03-08-2009, 02:27 PM
cbcharlie's Avatar
2009 C300 4Matic Sport P2/MM/Steel Gray
I was about to order some, but I looked at my wheels and noticed I already have them! maybe it's standard on the 09's? I definitely didn't pay for them. hopefully the key is somewhere in the car
Old 03-08-2009, 06:06 PM
Egonvdv's Avatar
E 300 AMG-Line diesel-Hybrid - 2021
Well you know my answer!
Egon
Old 03-09-2009, 04:21 PM
Derspeed's Avatar
X3 and 2012 C coming soon
Originally Posted by Savage c-300
i have aftermarket rims and for some reason they only sell the wheel locks in a set of 24 for my size. McGard 27200. You guys think its overkill if i change all my lugs to the wheels locks?
also, the wheel locks are slightly shorter then the current lugs; that's ok right?
You need seven turns.
Old 03-09-2009, 10:22 PM
Savage c-300's Avatar
C300 Sport, MM, P1
can you clarify what that means derspeed?
Old 03-10-2009, 09:40 AM
  #32
tanktube67's Avatar
2008 Black Out C350 Saks Edition / 87 VW GTI
A turn means 360 degrees
Old 03-10-2009, 05:49 PM
  #33
C300 Sport, MM, P1
lol ok i know what the word "turn" means. i just didnt know what question he was answering with "you need 7 turns".
my orignial question was if you guys thought it was overkill to switch out every single lug nut to wheel lock lug nuts instead of just the one on each wheel. I'm asking this because they sell my wheel lock in packs of 24.
my second question was if it was ok for the wheel lock to be slightly shorter (maybe 2to3 mm shorter) then the orignial lug nut.
dont get me wrong, i appreciate an answer, i just didnt know what it was answering with "you need 7 turns".
Old 03-10-2009, 10:11 PM
  #34
bones932's Avatar
2008 Mercedes C230 Sport
Wheel Locks
Mine came stock.
Old 03-10-2009, 10:32 PM
  #35
tanktube67's Avatar
On my opinion 20 lock nuts is over kill, But if you do torque the locks to 85 ft-lbs
Old 03-10-2009, 11:55 PM
  #36
Distalero's Avatar
C 300
Originally Posted by RLE
I don't know what in hell a stractor is but I like the deep sucket part.
I've had a little experience, so I know the difference. A stractor finishes the sucket part the right way. A schpritzer doesn't
Old 03-11-2009, 11:41 AM
  #37
GateKeeper's Avatar
GLA45 AMG, GLC43 AMG
It must make at least 7 full turns as your screwing in the lug nut to have enough holding grip, and so it won't extract itself, if there is not enough of the lug screwed in.
24 locking lug nuts,,,yaaa a bit of over kill IMHO, but are you sure they are all with the special lock on the face or are you getting all new lug nuts and only 4 out of all the others are really using the special key to put on and remove ? What company of lug nuts is this, that sells 24 locking lug nuts ?
McGard lock nuts if you can get them will work just fine, and are packaged with only 4 of them, and the special key.
Old 03-11-2009, 11:52 AM
  #38
vic viper's Avatar
S213
I have loosend a lot of rim locks at work and I must say that OEM MB locks are by far the toughest to crack.
On many of the cheaper locks it is easy to slam on a smaller socket or to use a socket with hardened left threads inside and they pop right off, but the MB ones have a hardened surface and if they sit hard it will take 30 mins+ to loosen all four at a workshop!
Old 03-19-2009, 07:46 PM
  #39
rcoppens's Avatar
R230
I do believe that the MB OEM lock nuts are made by Mcgard......
Old 03-20-2009, 01:25 AM
  #40
vic viper's Avatar
S213
What makes you think that?
Quick Reply: Wheel Locks
