Upgrading to C63 brakes
Old 05-06-2010, 10:32 PM
  #51
tls1212's Avatar
A45 AMG Edition 1
Originally Posted by perdikoula888
This is totally incorrect. You can fit c63 hubs to normal non amg 204 and fit the c63 brake calipers wth no problem. No aftermarket parts required, neither I would ever fit custom taiwanese brackets as they might be a serious safety risk.
yup u can choose either change the c63 hub to non amg 204 but tht will cost more on part,beside tht using tht aftermarket caliper bracket wont effected anything as you know taiwan have been produced a lot of aftermarket brake kit for sports car interms of quality should be reach international standard,just like you the carbon fiber lip most of them produce from taiwan.
Old 05-06-2010, 11:12 PM
  #52
absolutleo's Avatar
c300
yup.. i've seen a lot of decent quality products from taiwan.
taiwanese quality is much greater than chinese quality
Old 05-07-2010, 02:06 PM
  #53
perdikoula888's Avatar
I don't think that taiwanese no-name custom brackets have passed any certification or any safety test, neither they are approved for use. Small variations to the offsets and mounting points can be dangerous. Even with the best designed brackets, it is almost impossible to reach the exact mounting points and dimensions of the original mounted brake positions. Of course everyone is entitled to their opinion, and I might be biased because I have already retrofitted my C63 amg BBK with all original MB parts to my w204. However my opinion is that if someone has already spent a lot of money for original c63 BBK amg brakes it is a shame to use cheap aftermarket taiwanese no-name brackets.
Old 08-15-2010, 07:47 PM
  #54
AMGnutt's Avatar
2017 C-Class AMG
C63 brake upgrade
What is needed; the front hub and spindles or just the hub for the C63 brake upgrade? I purchased the OEM rotor disc & calipers...just need someone to put them on. Conversion Bracket or $$$ for hubs?
Old 08-15-2010, 07:48 PM
  #55
AMGnutt's Avatar
2017 C-Class AMG
C63 brake upgrade
Where do you purchase the Bracket for the the C63 brake upgrade?
Quick Reply: Upgrading to C63 brakes
